Optimize your workspace with this 21.5" monitor featuring USB-C connectivity, a small footprint and productivity-boosting features.
All in one
Declutter your desk with the included USB-C cable, a single cable solution that transmits power, data, video and audio. -
Big convenience in one cable
Get an easy charge with USB-C, the same cable that connects your device to the monitor. -
Connect to productivity
Easily daisy chain up to two FHD monitors with DisplayPort 1.2 output. -
Smooth transitions
Conveniently connect to a variety of laptops, or switch seamlessly between users, thanks to USB-C connectivity - ideal for shared workspaces. -
More room to work
With a thin profile and the smallest base in its class, you can free up valuable desk space. -
Expand your efficiency
The three-sided ultrathin bezel design lets you enjoy an uninterrupted view of your content across multiple monitors. And, with dual monitors, you can increase your productivity by up to 18%. -
More ways to multitask
Work conveniently across multiple screens and select from predefined templates with the Easy Arrange feature on Dell Display Manager software. Quickly tile and arrange your applications and get back to work faster with Auto-restore, a feature that remembers where you left off. -
Consistent and rich colors
A wide viewing angle enabled by In-plane switching technology lets you see vibrant colors - no matter where you sit. -
Clean and clutter-free
Focus on your work while hiding away cable clutter with an improved cable management design. -
Easy on the eyes
This TUV Certified monitor has a flicker-free screen with ComfortView, a feature that reduces harmful blue light emissions. It's designed to optimize eye comfort even over extended viewing. -
Adjust to your comfort
Pivot, tilt, swivel and adjust the height of your monitor for a comfortable setup all day long. Or choose from a variety of mounts and stands, including VESA, for even more flexibility.
- Dell P2219HC - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class A
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 19 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931)
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 48.73 cm x 16.6 cm x 35.34 cm
- RoHS
- 3-year warranty
- Bundled Services
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Designed For
- Latitude 7400 2-in-1; XPS 13 9380, 15 9570
- Display Type
- Energy Class
- Class A
- 28 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Pixel Per Inch
- 102
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (CIE 1931)
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- BFR/PVC-free, Mercury free, arsenic free
- 48.73 cm x 16.6 cm x 35.34 cm - with stand
- DisplayPort ¦ DisplayPort output ¦ HDMI ¦ USB-C ¦ 2 x USB 3.0 downstream (Type A) ¦ 2 x USB 2.0 downstream (Type A)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Included Accessories
- Cable tie
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort ¦ 1 x USB-C cable
- RoHS
- Security Slot Type
- Kensington security slot
- Input Voltage
- 19 W
- Power Consumption (Typical)
- 17 Watt
- Power Consumption Stand by
- 0.3 Watt
- On / Off Switch
- No
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
- Without stand - width: 48.73 cm - depth: 4.13 cm - height: 29.34 cm - weight: 3.05 kg ¦ With stand - width: 48.73 cm - depth: 16.6 cm - height: 35.34 cm
- Shipping Weight
- 6.43 kg
- Limited warranty - parts and labour - 3 years
- Bundled Services
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Designed For
- Dell Latitude 7400 2-in-1 ¦ Dell XPS 13 9380, 15 9570
