Dell Optiplex Micro Console with DVD-RW
Quicklinx: CP3BWS00 Mfr#: 492-BBMI
The Dell OptiPlex micro console enclosure designed and tested specifically for OptiPlex micro systems, this enclosure integrates seamlessly for system security while also adding the functionality of a DVD-RW drive. It allows you to deliver the desired computing experience without fear of theft or system tampering. The compact enclosure design protects your OptiPlex system. Moreover this enclosure allows for effective computing in environments such as retail stores and schools where security and system integrity is a concern.
  • Secure your OptiPlex system and add a DVD-RW drive
    The Dell OptiPlex micro console enclosure lets you easily secure your OptiPlex micro PC directly under a display, while also adding the flexibility and performance of a DVD-RW drive. The compact enclosure, designed to sit under a desktop display, also helps keep workspaces clutter-free.
  • Computing in any environment
    This enclosure allows for effective computing in environments - such as retail stores and schools - where security and system integrity is a concern. This allows you to deliver the desired computing experience without fear of theft or system tampering.
  • A solution for both security and productivity
    With a slide-on top cover and integrated lock slot, your OptiPlex micro PC will be secure while retaining its productivity. Plus, the addition of a DVD-RW drive expands computing power. The compact enclosure design protects your OptiPlex system.
  • An ideal companion for OptiPlex micro systems
    Designed and tested specifically for OptiPlex micro systems, this enclosure integrates seamlessly for system security while also adding the functionality of a DVD-RW drive.
Dell OptiPlex Micro Console Enclosure - micro PC enclosure
Micro PC enclosure
Built-in Devices
DVD-RW drive
OptiPlex 3020 (micro), 9020 (micro)
Micro PC enclosure
Built-in Devices
DVD-RW drive
Dell OptiPlex 3020 (micro), 9020 (micro)
