Dell OptiPlex 7760 AIO i7-8700 16GB 500GB SSD Win 10 Pro
Quicklinx: F2P3WS00 Mfr#: 992F7
Processor Type: Core i7
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 512GB
Storage Type: SSD
  • Core i7
  • IEEE 802.11n
£1,437.61 ex VAT
£1,725.13 inc VAT
  • Elegant and expansive
    The brilliant edge-to-edge display makes it easy to present, share and display more onscreen information to reduce scrolling and improve productivity.
  • Hear the meeting clearly
    State-of-the-art noise reduction through Waves MaxxAudio Pro and the quad mic array enable crystal-clear collaboration up to 12 feet away. The premium integrated speakers allow for crisp communication.
  • Enhanced security
    The pop-up web camera hides safely out of sight when not in use and adds a layer of security with facial recognition.
  • Stay connected with ease
    Equipped with a side mounted USB Type-C for easy access and speedy data transfer and a USB PowerShare port to conveniently charge other devices even when the system is powered down. Plus, the included Media Card Reader SD4.0 allows for fast data transfer from a variety of memory cards.
  • Multiple ways to display
    DisplayPort and HDMI 2.0 ports provide modern digital connectivity with support for two additional monitors so you can view more information on screen without minimize or closing applications.
  • Easy access
    Thanks to a toolless design, you can slide off the back cover with minimum effort, allowing you to maintain and upgrade with ease.
Dell OptiPlex 7760 - all-in-one - Core i7 8700 3.2 GHz - 16 GB - 512 GB - LED 27"
Personal computer - all-in-one
Platform Technology
Intel vPro Technology
1 x Intel Core i7 (8th Gen) 8700 / 3.2 GHz (4.6 GHz) (6-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
16 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
1 x SSD 512 GB - PCI Express - M.2
Optical Storage
No optical drive
Card Reader
Monitor
27" - LED - 1920 x 1080 (Full HD)
Graphics Controller
Intel UHD Graphics 630
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, 802.11ac Wave 2, Bluetooth 5.0
OS Provided
Silver
61.4 cm x 5.77 cm x 38.9 cm
8.41 kg
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - on-site
Platform Technology
Personal computer
Product Form Factor
All-in-one - with height-adjustable stand
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Silver
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
16 GB / 32 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 16 GB
Hard Drive
SSD - M.2
1 x 512 GB
Interface Type
PCI Express
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
LED - IPS
Diagonal Size
27"
Native Resolution
Widescreen Display
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Pixel Pitch
0.3114 mm
Response Time
25 ms
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
Sound Output Mode
Stereo
High Definition Audio, Wave MAXXAudio Pro
Speakers Included
2 x right / left channel
Input Device
Keyboard (on selected markets only)
Audio Input
Quad array microphone
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
Remote Wake Up, PXE support
Bays
Internal 2.5"
Slots
M.2 Card
2 x USB 3.1 Gen 1 (2 rear) (supports SmartPower On) , 1 x USB 3.1 Gen 1 (PowerShare) , 2 x USB 3.1 Gen 1 (2 rear) , 1 x USB-C 3.1 Gen 2 , 1 x LAN (Gigabit Ethernet) - RJ-45 (1 rear) , 1 x HDMI output (1 rear) , 1 x DisplayPort (1 rear) , 1 x audio line-out (1 rear) , 1 x headphones/microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Pricing Type
Build To Plan (BTP)
Power supply
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
Microsoft Office (Trial)
Dimensions & Weight Details
28.7 cm - 25.48 cm - 3.22 kg - stand
61.4 cm
5.77 cm
38.9 cm
8.41 kg
Shipping Width
91.8 cm
Shipping Depth
21.6 cm
Shipping Height
54.8 cm
Shipping Weight
16 kg
Dell OptiPlex 7760 AIO i7-8700 16GB 500GB SSD Win 10 Pro Bundle deal on Dell OptiPlex 7760 AIO i7-8700 16GB 500GB SSD Win 10 Pro
£1,624.07
saving £8.33
£1,537.37
Storage Type: SSD
Processor Model: I7-8700
Type: Personal computer
Case Style: All-in-one
Optical Storage: None
Brand: Dell
Price Range Ex VAT: 1000 - 1500
