Power through your everyday tasks with Intel Core processors, as well as the latest discrete graphics. Dell also offers comprehensive encryption, advanced authentication and malware prevention from a single source, so you can protect data from device to the cloud. Built-in management features simplify and automate lifecycle management of your OptiPlex.
Get the job done
Power through your everyday tasks with Intel Core processors, as well as the latest discrete graphics. -
What you need, when you need it
Quickly boot the files and applications you use the most with Intel Smart Response technology. -
Unmatched security in its class
Protect data with the most secure family of commercial desktops on the market. Dell offers comprehensive encryption, advanced authentication and malware prevention from a single source, so you can protect data from device to the cloud. -
Dell Data Protection (DDP)
Enable central management of advanced authentication. -
Trusted Computing Group (TCG)-certified
The OptiPlex 7020 is fortified by the TCG-certified Trusted Platform Module, a hardware device that adds an extra layer of data protection and secure credential storage. -
Simplify and automate lifecycle management of your OptiPlex fleet with best-in-class integration into Microsoft System Center and Dell KACE appliances - and save valuable time and resources. -
Dell command center
Save time and eliminate guesswork with automated tools and utilities for deploying, monitoring and updating systems. -
Easy to service
The OptiPlex 7020 has a tool-less chassis design to make it quick and easy to perform routine maintenance, saving you some valuable time and resources. -
Durability
The Dell OptiPlex 7020 is made with durable materials that measure up against real-world conditions. It has undergone Dell Highly Accelerated Life Cycle Testing (H.A.L.T.) and has withstood engineers' tolerance limits for heat, cold, vibration, shocks and drops.
- Dell OptiPlex 7020 - SFF - Core i5 4590 3.3 GHz - 4 GB - HDD 500 GB
- Personal computer - small form factor
- Processor
- Intel Core i5 (4th Gen) 4590 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics 4600
- Audio Output
- Integrated
- Networking
- GigE
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro 64-bit Licence
- Software Included
- Windows 8.1 Pro 64-bit (DVD)
- 9.3 cm x 31.2 cm x 29 cm
- 6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - response time: next business day
- Personal computer
- Product Form Factor
- Small form factor
Processor / Chipset
- CPU
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel Q87
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
Input Device
- Mouse (on selected markets only), keyboard (on selected markets only)
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2 x 2.5"/3.5" shared
- Slots
- 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x16 (x4 mode)
- 6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 2 x audio line-out/headphones , 2 x audio line-in/microphone , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x DisplayPort , 1 x VGA
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, E-Standby, CECP, China RoHS
- Power supply
- Power Provided
- 255 Watt
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- 9.3 cm
- 31.2 cm
- 29 cm
- 6 kg
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.82 |
