Power through your everyday tasks with Intel Core processors, as well as the latest discrete graphics. Dell also offers comprehensive encryption, advanced authentication and malware prevention from a single source, so you can protect data from device to the cloud. Built-in management features simplify and automate lifecycle management of your OptiPlex.
Get the job done
Power through your everyday tasks with Intel Core processors, as well as the latest discrete graphics. -
What you need, when you need it
Quickly boot the files and applications you use the most with Intel Smart Response technology. -
Unmatched security in its class
Protect data with the most secure family of commercial desktops on the market. Dell offers comprehensive encryption, advanced authentication and malware prevention from a single source, so you can protect data from device to the cloud. -
Dell Data Protection (DDP)
Enable central management of advanced authentication. -
Trusted Computing Group (TCG)-certified
The OptiPlex 7020 is fortified by the TCG-certified Trusted Platform Module, a hardware device that adds an extra layer of data protection and secure credential storage. -
Simplify and automate lifecycle management of your OptiPlex fleet with best-in-class integration into Microsoft System Center and Dell KACE appliances - and save valuable time and resources. -
Dell command center
Save time and eliminate guesswork with automated tools and utilities for deploying, monitoring and updating systems. -
Easy to service
The OptiPlex 7020 has a tool-less chassis design to make it quick and easy to perform routine maintenance, saving you some valuable time and resources. -
Durability
The Dell OptiPlex 7020 is made with durable materials that measure up against real-world conditions. It has undergone Dell Highly Accelerated Life Cycle Testing (H.A.L.T.) and has withstood engineers' tolerance limits for heat, cold, vibration, shocks and drops.
- Dell OptiPlex 7020 - MT Core i5 4590 3.3 GHz - 4 GB - HDD 500 GB
- Personal computer - MT - chassis intrusion detection
- Processor
- Intel Core i5 (4th Gen) 4590 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics 4600
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Licence
- Software Included
- Microsoft Office (Trial), Windows 8.1 (DVD)
- Black
- 17.5 cm x 41.7 cm x 36 cm
- 9.4 kg
- Limited warranty - 3 years - response time: next business day
- Personal computer
- Product Form Factor
- MT
- Embedded Security
- Trusted Platform Module (TPM) Security Chip
- Black
Processor / Chipset
- CPU
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel Q87
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 3 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 4
Optical Storage
- DVD±RW DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- High Definition Audio
Input Device
- Mouse (on selected markets only), keyboard (on selected markets only)
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Bays
- 2 (total) / 1 (free) x external 5.25" , 2 (total) / 1 (free) x internal 2 x 2.5"/3.5" shared
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 1 (free) x PCI - full-height
- 6 x USB 2.0 (2 front, 4 rear) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in/microphone , 1 x audio line-out , 1 x serial , 1 x VGA , 2 x DisplayPort
- Chassis intrusion detection
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Power supply
- Voltage Required
- Power Provided
- 290 Watt
Operating System / Software
- OS Provided
- Software
- 17.5 cm
- 41.7 cm
- 36 cm
- 9.4 kg
- 0 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £17.42 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.32 |
C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black | In Stock | £16.66 |
