Dell Optiplex 5270 AIO 21.5" Intel Core i5-9500 8GB 500GB Windows 10 Professional 64-bit
Quicklinx: FDZ4WS00 Mfr#: DF5DX
  • IEEE 802.11n
  • Core i5
21.5'' narrow-bezel all-in-one desktop with Full HD and customized deployment options for a smart workspace.
  • Efficiency in every inch
    Witness crystal clear clarity from every pixel with a 21.5" narrow-bezel Full HD IPS display (1920x1080).
  • Unconstrained team work
    Experience faster collaboration with integrated speakers, a dual array microphone, and a Full HD pop-up camera. Perfect for call centers, kiosks and educational environments that benefit from video and telephone conference capabilities.
  • Rich connectivity options
    Numerous port options create a smart and unified way to connect and share from your devices. Bluetooth 5 and 802.12ac 2x2 wireless LAN enables you to work without wires. A side-mounted USB-C 3.1 Gen2 port allows easy access and speedy data transfer along with a USB PowerShare that keeps your peripherals charged even while the system is off. And with multiple USB ports and a DisplayPort, you can view more information on screen without minimizing or closing applications.
Dell OptiPlex 5270 All In One - all-in-one - Core i5 9500 3 GHz - 8 GB - HDD 500 GB - LED 21.5"
Personal computer - all-in-one
Bundled Services
3 Years Basic Onsite
Intel Core i5 (9th Gen) 9500 / 3 GHz (, up to 4.4 GHz, (6-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA - 7200 rpm
Optical Storage
No optical drive
Card Reader
Monitor
21.5" - LED - 1920 x 1080 (Full HD) @ 60 Hz
Graphics Controller
Intel UHD Graphics 630
Camera
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Microsoft Office (Trial)
49.8 cm x 5.45 cm x 32.9 cm
5.33 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Personal computer
Bundled Services
Product Form Factor
All-in-one - with height-adjustable stand
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3 GHz
Max Turbo Speed
4.4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel Q370
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
LED - IPS
Diagonal Size
21.5"
Native Resolution
V-Sync Rate at Max Res.
60 Hz
Widescreen Display
Horizontal Viewing Angle
89
Vertical Viewing Angle
89
Pixel Pitch
0.2745 mm
Response Time
25 ms
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
2 Megapixel
Resolution
Full HD
Pop up camera, 74.9 degrees
Input Device
Keyboard (on selected markets only)
Keyboard
Keyboard Name
Dell KB216 Wired Keyboard
USB
Audio Input
Array microphone
Ethernet Controller
Intel I219-V
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
Remote Wake Up, PXE support, MU-MIMO Support
Bays
Internal 2.5"
Slots
M.2 Card
2 x USB 2.0 (2 rear) (Power on/Wake-up support) , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.1 Gen 1 (PowerShare) , 2 x USB 3.1 Gen 1 (2 rear) , 1 x USB-C 3.1 Gen 2 , 1 x DisplayPort , 1 x audio line-out (1 rear) , 1 x headphones/microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Pricing Type
Power supply
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.1
Dimensions & Weight Details
49.8 cm - 5.45 cm - 32.9 cm - 5.33 kg - without stand , 25.64 cm - 22.5 cm - 3.01 kg - stand
49.8 cm
5.45 cm
32.9 cm
5.33 kg
Shipping Width
79.8 cm
Shipping Depth
19.2 cm
Shipping Height
48.6 cm
Shipping Weight
12.4 kg
FDZ4 Dell Slim DW316 USB External DVD Drive In Stock £36.19
FDZ4 Dell Dell KB-522 Wired Business Multimedia USB Keyboard - Black In Stock £18.16
FDZ4 Dell KB-813 Smart Card Reader In Stock £42.82
FDZ4 Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £41.60
FDZ4 Dell MS5120W Mobile Pro Wireless Mouse In Stock £18.91
