Dell Optiplex 5050 SFF Core i5-7500 8GB 128GB SSD Windows 10 Pro
Quicklinx: CQYDWS00 Mfr#: VP7RF
  • Core i5
Expandable tower and small form factor desktops with business-critical features companies need with the space to add additional peripherals.
Stay flexible: With full-power features in a smart, dual orientation design, the OptiPlex 5050 lets you maximize your work environment. Towers can be setup on or under your desk, while the small form factor can be combines with the new OptiPlex Small Form Factor All-in-One stand to create versatile, flexible solutions for any office situation.
Secure and unified: These optional cable covers reduce clutter, prevent access to the ports and cables in the back of the system and seamlessly match the OptiPlex's elegant design, so your setup looks unified and stays protected.
Easy access: With a tool-less design and a simple removable side panel, you have easy access to key system components such as drives and memory so your system can be updated, remaining viable for years to come.
Power your success: Intel 7th Gen processors make this the fastest OptiPlex yet.
Smooth, speedy performance: Upgraded 2400MHz DDR4 is the fastest and most efficient memory available, so you can work with lags or crashes.
Connect with ease: Two display ports, native 3 display support, and HDMI with optional VGA, as well as legacy ports provide ample connection to your devices and networks.
Always up to date: Every OptiPlex 5050 is available with Dell Command Suite, making driver, BIOS, and firmware updates easier. These free tools allow flexible and automated BIOS or system configurations for your company, allowing you to manage your fleet easily and securely every time.
Work remotely, with confidence: Optional Intel Systems Management allows for remote and advanced out of band management capabilities for increased productivity and lower risk.
  • Stay flexible
    With full-power features in an incredibly condensed design, the OptiPlex 5050 lets you maximize your work environment. The Micro All-in-One stand and multiple mounting options create versatile, flexible solutions to any office situation.
  • Mount it and forget it
    The OptiPlex Micro DVD/RW Enclosure lets you secure your micro PC directly on a wall or under a desk - with the added performance of a DVD/RW drive, so you can watch and share data easily with system, while the Micro stays out of sight.
  • Easy access
    With a tool-less design and a simple removable side panel, you have easy access to key system components such as drives and memory so your system can stay up to date for longer, remaining viable for years to come.
Dell OptiPlex 5050 - SFF - Core i5 7500 3.4 GHz - 8 GB - 128 GB
Personal computer - small form factor
1 x Intel Core i5 (7th Gen) 7500 / 3.4 GHz (3.8 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 128 GB - SATA 6Gb/s - M.2
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630
GigE
OS Provided
Windows 10 Pro 64-bit Edition
29.2 cm x 9.26 cm x 29 cm
5.14 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - response time: next business day
Personal computer
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 64 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered
Configuration Features
2 x 4 GB
Hard Drive
SSD - M.2
1 x 128 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI, DisplayPort
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
Keyboard Name
Dell KB216 Wired Keyboard
USB
Mouse
Optical
USB
Ethernet Controller
Intel I219-V
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2x2.5" / 1x3.5" shared
Slots
1 (total) / 1 (free) x PCIe x16 - half-height , 1 (total) / 1 (free) x PCIe x16 - half-height (x4 mode) , 1 (total) / 0 (free) x M.2 Card
3 x USB 2.0 (1 front, 2 rear) , 6 x USB 3.0 (2 front, 4 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out (1 rear) , 1 x serial , 1 x USB 2.0 (1 in front) (PowerShare) , 1 x HDMI , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA
RoHS, WEEE, CECP
Pricing Type
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
Microsoft Office (Trial)
ENERGY STAR Certified
ENERGY STAR Version
6.0
29.2 cm
9.26 cm
29 cm
5.14 kg
