Dell OptiPlex 3010 Intel Core i5-3470 4GB 500GB Win 8 Pro
Quicklinx: 8HWYWS00 Mfr#: 94639126/2-3
  • Core i5
Inspire your workforce with the Dell™ OptiPlex™ 3010, designed for essential productivity, stable life cycles and simple IT control.
Smart productivity Work efficiently with the OptiPlex™ 3010 desktop, featuring essential performance, flexibility and connectivity to help your organization succeed.
Achieve high performance. Harness up to Intel® Core™ i5 processor options including Intel® Turbo Boost Technology 2.0, ample storage, Intel® HD graphics and high-bandwidth memory of the OptiPlex 3010.
Experience workplace convenience and versatility. Work comfortably with a system that enables you to customize your workspace with intuitive design, multiple display options and flexible configurations for your peripherals.
Easy collaboration promotes success. Collaborate and share data through VoIP and Microsoft® Unified Communication certifications.
Business-class control Effective management of your office environment is within reach. The OptiPlex™ 3010 enables IT administrators to take total control over system management and security protocols, and offers the stability needed to effectively plan for the future.
Efficiently manage your desktop fleet. Achieve unprecedented IT control in your workplace. In-band management, image sharing between desktops and Dell's System Center Configuration Manager help increase IT efficiency.
Ensure data security across your organization. Help protect your critical data and meet compliance standards with Dell Data Protection , Encryption3 and other security features.
Enjoy the peace of mind provided by business-class stability and support. As your business grows, hardware stability and support are the key to budget management and forecasting long-term needs. Help IT focus on the most important projects with Dell ProSupport™ and Dell Deployment Services.
Inspired design. Built to last and designed to fit your workspace, Dell OptiPlex™ desktops offer durability and style.
Built to last. Your business requires a desktop that can handle the tough jobs. Ensure long-term reliability with durable, serviceable Dell OptiPlex desktops.
The right fit for your desk. Dell OptiPlex systems are designed to integrate seamlessly into any office environment, on virtually any size desk, and with a consistent look across all models.
Designed to help preserve the environment. Help minimize energy consumption and encourage conservation with the ENERGY STAR® 5.2 compliant OptiPlex desktops, featuring highly efficient power supply options and environmentally conscious design features.
Desktop PC
Processor Type
Core i5
Processor Model
3470
Installed Memory
4 GB
Optical Storage
DVD±RW
Operating System
Microsoft Windows 8 Professional 64-bit Edition
Case Style
Small Form Factor
Display
no
Hard Drive Capacity
500 GB
