OptiPlex 3000 Thin Client|TPM|Celeron N5105|4GB|32GB eMMC|Integrated|65W|Verti Stand|Mouse|ThinOS|3Y ProSpt.
Select your software solution for success:
Three different operating systems are available, including Dell ThinOS, Ubuntu Linux with optional Dell Hybrid Client software and Windows 10 IoT Enterprise. -
Connect from anywhere:
OptiPlex offers support for Wi-Fi 6E, a next generation technology that brings you faster speeds and better performance, wherever you choose to work. -
Broaden your horizons:
Support for up to three displays at 4K resolution makes it easier for you to multi-task or simply see the bigger picture. -
More powerful processing:
Intel Celeron and Pentium Quad Core processors bring instant and seamless access to digital and virtual workspaces. -
Ultra-secure:
Work confidently with a multitude of security features, including firmware TPM 2.0, standard security lock slot, Padlock loop, Intrusion switch and the protection of Dell cloud client workspace software. -
Memory that offers more:
Unlock your multi-tasking potential and achieve even more with up to 16GB DDR4 memory. -
Compact, fan-less design:
Delivers a quiet, durable computing experience. -
Flexible Fit:
An all-new variety of mounts for the OptiPlex 3000 Thin Client offers flexibility in how you set up your work environment. -
Simple to maintain:
Easy access without removing the front bezel simplifies serviceability.
- Dell OptiPlex 3000 Thin Client - DTS Celeron N5105 2 GHz - 4 GB - flash 32 GB
- Thin client - DTS
- Bundled Services
- 3 Years ProSupport
- Processor
- 1 x Intel Celeron N5105 / 2 GHz (up to 2.9 GHz, (Quad-Core)
- Processor Main Features
- Intel Burst Technology
- Cache Memory
- 4 MB
- Cache Per Processor
- 4 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR4 SDRAM
- Hard Drive
- Flash 32 GB - eMMC
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics
- Networking
- 1GbE
- Power
- (50/60 Hz)
- OS Provided
- Dell ThinOS
- Black
- 3.6 cm x 17.8 cm x 18.2 cm
- 1.104 kg
- Pricing Type
- Build To Stock (BTS)
- Thin client
- Bundled Services
- Product Form Factor
- DTS
- Embedded Security
- Trusted Platform Module (TPM) Security Chip
- Black
Processor / Chipset
- CPU
- Intel Celeron N5105
- Clock Speed
- 2 GHz
- Max Turbo Speed
- 2.9 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 4 MB
- 4 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2933 MHz
- Rated Memory Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- Flash - eMMC
- Capacity
- 1 x 32 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Input Device
- Mouse (on selected markets only)
Mouse
- Mouse Name
- Dell MS116 Wired Mouse
- Ethernet Controller
- Realtek RTL8111HSD
- Data Link Protocol
- Slots
- 2 (total) / 2 (free) x M.2 Card - 2230
- 3 x USB 2.0 (1 in front) (one of them supports SmartPower On) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x USB 3.2 Gen 1 (1 in front) , 2 x USB 3.2 Gen 2 , 2 x DisplayPort 1.4
- Included Accessories
- Vertical stand
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- Pricing Type
- Power adapter
- Voltage Required
- AC 100-240 V (50/60 Hz)
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Dell ThinOS
- 3.6 cm
- 17.8 cm
- 18.2 cm
- 1.104 kg
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
Accessories (2)
Dell Dual Monitor Stand - MDS19 | In Stock | £170.75 |
Dell OptiPlex Micro and Thin Client VESA Mount w/Adapter Bracket | In Stock | £24.78 |
Monitors (13)
Dell UltraSharp 24" 1920 x 1080 5 ms IPS | In Stock | £174.41 |
Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor | In Stock | £354.19 |
Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor | In Stock | £88.32 |
Dell P2425HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £176.36 |
Dell UltraSharp U3824DW 38" 3840x1600 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £807.37 |
Dell UltraSharp U2724D - LED monitor - QHD - 27" | In Stock | £277.64 |
Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £138.74 |
Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £108.44 |
Dell P242524" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £135.59 |
Dell UltraSharp U2424HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £208.68 |
Dell P2424HEB 24" 1920x1080 5ms HDMI DisplayPort IPS LED Video Conferencing Monitor | In Stock | £260.30 |
Dell P2424HT 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £253.39 |
Dell P2725HE 27" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £192.99 |
Keyboards and Mice (5)
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £50.15 |
Dell MS5120W Mobile Pro Wireless Mouse | In Stock | £18.91 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £59.66 |
Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot | In Stock | £43.95 |
Dell Dell Mobile Wireless Mouse - MS3320W - Black | In Stock | £19.29 |
Other bundles (3)
Dell Slim DW316 USB External DVD Drive | In Stock | £36.19 |
Dell SB521A Magnetic Sound bar | In Stock | £30.78 |
Dell Dell Speakerphone SP3022 | In Stock | £61.41 |
