Dell OptiPlex 3000 Thin Client Intel Celeron N5105 4GB 32GB eMMC ThinOS
Quicklinx: H8SNWS00 Mfr#: HR6JT
Processor Type: Celeron
Operating System: Dell ThinOS
Installed Memory: 4GB
Hard Drive Capacity: 32GB
Storage Type: Flash
  • Celeron
£184.54 ex VAT
£221.44 inc VAT
OptiPlex 3000 Thin Client|TPM|Celeron N5105|4GB|32GB eMMC|Integrated|65W|Verti Stand|Mouse|ThinOS|3Y ProSpt.
  • Select your software solution for success:
    Three different operating systems are available, including Dell ThinOS, Ubuntu Linux with optional Dell Hybrid Client software and Windows 10 IoT Enterprise.
  • Connect from anywhere:
    OptiPlex offers support for Wi-Fi 6E, a next generation technology that brings you faster speeds and better performance, wherever you choose to work.
  • Broaden your horizons:
    Support for up to three displays at 4K resolution makes it easier for you to multi-task or simply see the bigger picture.
  • More powerful processing:
    Intel Celeron and Pentium Quad Core processors bring instant and seamless access to digital and virtual workspaces.
  • Ultra-secure:
    Work confidently with a multitude of security features, including firmware TPM 2.0, standard security lock slot, Padlock loop, Intrusion switch and the protection of Dell cloud client workspace software.
  • Memory that offers more:
    Unlock your multi-tasking potential and achieve even more with up to 16GB DDR4 memory.
  • Compact, fan-less design:
    Delivers a quiet, durable computing experience.
  • Flexible Fit:
    An all-new variety of mounts for the OptiPlex 3000 Thin Client offers flexibility in how you set up your work environment.
  • Simple to maintain:
    Easy access without removing the front bezel simplifies serviceability.
Dell OptiPlex 3000 Thin Client - DTS Celeron N5105 2 GHz - 4 GB - flash 32 GB
Thin client - DTS
Bundled Services
3 Years ProSupport
1 x Intel Celeron N5105 / 2 GHz (up to 2.9 GHz, (Quad-Core)
Processor Main Features
Intel Burst Technology
Cache Memory
4 MB
Cache Per Processor
4 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM
Hard Drive
Flash 32 GB - eMMC
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics
1GbE
(50/60 Hz)
OS Provided
Dell ThinOS
3.6 cm x 17.8 cm x 18.2 cm
1.104 kg
Pricing Type
Build To Stock (BTS)
Thin client
Bundled Services
3 Years ProSupport
Product Form Factor
DTS
Embedded Security
Trusted Platform Module (TPM) Security Chip
Processor / Chipset
CPU
Intel Celeron N5105
Clock Speed
2 GHz
Max Turbo Speed
2.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
4 MB
Cache Per Processor
4 MB
RAM
Installed Size
DDR4 SDRAM
Effective Memory Speed
2933 MHz
Rated Memory Speed
3200 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
Flash - eMMC
1 x 32 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel UHD Graphics
Video Interfaces
DisplayPort
Input Device
Mouse (on selected markets only)
Mouse
Mouse Name
Dell MS116 Wired Mouse
Ethernet Controller
Realtek RTL8111HSD
Slots
2 (total) / 2 (free) x M.2 Card - 2230
3 x USB 2.0 (1 in front) (one of them supports SmartPower On) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x USB 3.2 Gen 1 (1 in front) , 2 x USB 3.2 Gen 2 , 2 x DisplayPort 1.4
Vertical stand
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
Pricing Type
Power adapter
AC 100-240 V (50/60 Hz)
Power Provided
65 Watt
Operating System / Software
OS Provided
Dell ThinOS
3.6 cm
17.8 cm
18.2 cm
1.104 kg
35 °C
10 - 90% (non-condensing)
Accessories (2)
H8SN Dell Dual Monitor Stand - MDS19 In Stock £119.78
H8SN Dell OptiPlex Micro and Thin Client VESA Mount w/Adapter Bracket In Stock £24.78
Monitors (12)
H8SN Dell UltraSharp 24" 1920 x 1080 5 ms IPS In Stock £174.41
H8SN Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor In Stock £354.19
H8SN Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor In Stock £83.92
H8SN Dell P2425HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £163.52
H8SN Dell UltraSharp U3824DW 38" 3840x1600 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £917.48
H8SN Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £145.03
H8SN Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £106.88
H8SN Dell P242524" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £135.83
H8SN Dell UltraSharp U2424HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £219.92
H8SN Dell P2424HEB 24" 1920x1080 5ms HDMI DisplayPort IPS LED Video Conferencing Monitor In Stock £275.21
H8SN Dell P2424HT 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £275.13
H8SN Dell P2725HE 27" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £192.99
Keyboards and Mice (5)
H8SN Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £40.12
H8SN Dell MS5120W Mobile Pro Wireless Mouse In Stock £26.00
H8SN Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £59.66
H8SN Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot In Stock £43.95
H8SN Dell Dell Mobile Wireless Mouse - MS3320W - Black In Stock £13.49
Other bundles (3)
H8SN Dell Slim DW316 USB External DVD Drive In Stock £36.19
H8SN Dell SB521A Magnetic Sound bar In Stock £30.78
H8SN Dell Dell Speakerphone SP3022 In Stock £63.32
Storage Type: Flash
Processor Model: N5105
Type: Thin client
Case Style: Small form factor
Optical Storage: None
Brand: Dell
