Privacy filter for 12.5-inch laptops from Dell keep your on-screen data private. The on-screen data is visible with a 60-degrees viewing angle only to persons directly in front of the monitor, passersby only see a dark screen. The privacy filter protects student records from side viewing to enhance the integrity of testing centers. Whether computer users are accessing private information in public, or they are working in high-traffic areas, this Dell privacy filter is a vital part of a complete security solution. This filter is easy to install thanks to its frameless design and its compact size allows you to keep the privacy filter in place, even when you close your laptop. Moreover, it protect your valuable Dell ultrabook or laptop display from smudges, scratches and marks.
Keep on-screen information private
This Dell privacy filter features 3M technology that keeps others from seeing the information on your Dell laptop or ultrabook screen - without blocking your view. With a 60-degree viewing angle, this filter ensures users directly in front of the screen can see data clearly, but passersby from either side can only see a dark screen. -
Additional privacy for busy workspaces
Whether computer users are accessing private information in public, or they are working in high-traffic areas, this Dell privacy filter is a vital part of a complete security solution. Health care professionals can keep records and patient data private from onlookers, while workers in the government and finance sectors can more easily comply with privacy regulations by utilizing Dell privacy filters as part of their program. In education, the privacy filter protects student records from side viewing to enhance the integrity of testing centers. -
Frameless design protects your display
This Dell privacy filter is simple to install thanks to its frameless design and easy-on/easy-off attachment. Its compact size allows you to keep the privacy filter in place, even when you close your laptop. Keep it on to protect your valuable Dell ultrabook or laptop display from smudges, scratches, and marks. The filter can be safely and easily cleaned - even with many hospital disinfectants. -
Maintains image clarity and reduces glare
The filter has both matte and glossy sides, so you can pick the finish that makes working at your computer more convenient and comfortable.
- Dell - notebook privacy filter
- Product Type
- Notebook privacy filter
- Display Screen Size Compatibility
- 12.5"
- Anti-scratch
- 1-year warranty
- Designed For
- Chromebook 3120; Latitude 5280, 7280, E5250, E5270, E6220, E6230, E7240, E7250, E7270; XPS 12 (9Q33), 12 9250
- Product Type
- 12.5"
- Anti-scratch
- Limited warranty: - 1 year
- Designed For
- Dell Chromebook 3120 , Dell Latitude 5280, 7280, E5250, E5270, E6220, E6230, E7240, E7250, E7270 , Dell XPS 12 (9Q33), 12 9250
