N-series is a family of energy-efficient and cost-effective 1GbE and 10GbE switches designed for modernizing and scaling network infrastructure. Built to help keep operating costs down, the N2000 series can operate at temperatures up to 122 °F (50 °C) to help reduce cooling costs.
Upgrade your network
N-series is a family of energy-efficient and cost-effective 1GbE and 10GbE switches designed for modernizing and scaling network infrastructure. -
Designed for efficiency
Built to help keep operating costs down, the N2000 series can operate at temperatures up to 122 °F (50 °C) to help reduce cooling costs. -
Advanced feature set to simplify management
The Dell Networking N2000 series is designed for easy deployment, outstanding interoperability and a low learning curve for network administrators. -
Deploy with confidence at any scale
With high throughput and capacity to handle unexpected workloads, the N2000 series switches are ideal solutions for fast growing GbE networks that require high-density aggregation with seamless redundancy and availability.
- Dell Networking N2024 - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L2+ - Managed - stackable
- Enclosure Type
- Front to back airflow rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 2 x 10 Gigabit SFP+
- Performance
- Switching fabric bandwidth: 172 Gbps , Forwarding performance: 128 Mpps , Stacking bandwidth: 84 Gbps
- Capacity
- Virtual interfaces (VLANs): 4096 , ARP entries: 1024 , NDP entries: 400 , Priority queues per port: 8 , IPv4 routes (static): 256 , IPv6 routes (static): 128 , IPv4 routes (dynamic): 256 , VLAN routing interfaces: 256 , ACL: 100 , Max ACL rules system-wide: 2048 , Maximum rules per ACL: 1023 , Maximum ACL rules per interface (IPv4) ingress rules: 1024 , Maximum ACL rules per interface (IPv4) egress rules: 512 , Maximum ACL rules per interface (IPv6) ingress rules: 512 , Maximum ACL rules per interface (IPv6) egress rules: 256 , Maximum VLAN interfaces with ACLs applied: 24 , Maximum aggregation groups: 128 , Maximum dynamic ports per switch stack: 144 , Maximum member ports per LAG: 8
- MAC Address Table Size
- 8192 entries
- Routing Protocol
- RIP-1, RIP-2, static IPv4 routing, static IPv6 routing
- Remote Management Protocol
- Telnet, TFTP
- Flow control, auto-negotiation, VLAN support, port mirroring, DiffServ support, Broadcast Storm Control, IPv6 support, Access Control List (ACL) support, IPv4 support, Energy Efficient Ethernet, Management Information Base (MIB), dual firmware images, Neighbor Discovery Protocol (NDP), redundant fans
- 44 cm x 25.7 cm x 4.35 cm
- 3.69 kg
- Limited lifetime warranty
- Enclosure Type
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 8192 entries
- Routing Protocol
- Telnet, TFTP
- Encryption Algorithm
- MD5, AES, SSL, TLS
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 1 GB
- Flash Memory
- 256 MB
- 24 x Gigabit LAN RJ-45 , 2 x 10Gbit LAN SFP+ , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
- Power Device
- Internal power supply
- Installed Qty
- 1
- Power Provided
- 100 Watt
- 42.9 Watt
- Redundant Power System (RPS) connector
- Rack Mounting Kit
- Included
- FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, VCCI Class A, EAC, CCC Class A
- 44 cm
- 25.7 cm
- 4.35 cm
- 3.69 kg
- Limited warranty - lifetime
- 0 °C
- 45 °C
- 0 - 95%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 65 °C
- Humidity Range Storage
- 0 - 85%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
Dell SFP+ Transceiver Module 10 Gigabit Ethernet - 10GBase | In Stock | £157.30 |
Dell SFP (mini-GBIC) transceiver module GigE 1000Base-SX | In Stock | £80.51 |
