The N1500 switch series offers a power-efficient Gigabit Ethernet (GbE) network-access switching solution with integrated 10GbE uplinks. The N1500 switch series has high-performance capabilities and wire-speed performance, utilizing a non-blocking architecture to handle unexpected traffic loads easily. These switches offer simple management and scalability via a 40Gbps (full-duplex) high-availability stacking architecture that allows management of up to four switches from a single IP address.
Designed for efficiency
Built to help keep operating costs down, the N1500 Series can operate at temperatures up to 113°F (45°C) to help reduce cooling costs. -
Simplify management with advanced features
The Dell Networking N1500 Series delivers easy deployment, outstanding interoperability and a level learning curve for network administrators. -
Deploy with confidence at any scale
With high throughput and capacity to handle unexpected workloads, the N1500 Series switches are ideal solutions for fast-growing GbE networks that require high-density aggregation with seamless redundancy and availability.
- Dell Networking N1548P - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - L2+ - Managed - stackable
- Enclosure Type
- Front to back airflow rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 4 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 30.8 W
- Performance
- Switching fabric bandwidth: 176 Gbps , Forwarding performance: 164 Mpps
- Capacity
- Virtual interfaces (VLANs): 512 , ARP entries: 1024 , NDP entries: 400 , Priority queues per port: 8 , IPv4 routes (static): 256 , IPv6 routes (static): 128 , IPv4 routes (dynamic): 256 , VLAN routing interfaces: 128 , ACL: 100 , Max ACL rules system-wide: 2048 , Maximum rules per ACL: 1023 , Maximum ACL rules per interface (IPv4) ingress rules: 1023 , Maximum ACL rules per interface (IPv4) egress rules: 1023 , Maximum ACL rules per interface (IPv6) ingress rules: 512 , Maximum ACL rules per interface (IPv6) egress rules: 509 , Maximum VLAN interfaces with ACLs applied: 24 , Maximum dynamic ports per switch stack: 144 , Maximum member ports per LAG: 8 , MAC addresses: 16000
- MAC Address Table Size
- 16000 entries
- Routing Protocol
- RIP-1, RIP-2, static IPv4 routing, static IPv6 routing
- Remote Management Protocol
- Telnet, TFTP
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), port mirroring, Broadcast Storm Control, redundant fans
- 44 cm x 38.7 cm x 4.32 cm
- 7 kg
- Limited lifetime warranty
- Enclosure Type
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 30.8 W
- Performance
- Capacity
- 16000 entries
- Routing Protocol
- Telnet, TFTP
- Encryption Algorithm
- MD5, AES, SSL, TLS
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 1 GB
- Flash Memory
- 256 MB
- 48 x Gigabit LAN RJ-45 , 4 x 10Gbit LAN SFP+ , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A
- Power Device
- Internal power supply
- Installed Qty
- 1
- Power Provided
- 600 Watt
- Rack Mounting Kit
- Included
- FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, VCCI Class A, EAC, CCC Class A
- 44 cm
- 38.7 cm
- 4.32 cm
- 7 kg
- Limited warranty - lifetime
- 0 °C
- 45 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 65 °C
Dell SFP+ Transceiver Module 10 Gigabit Ethernet - 10GBase | In Stock | £188.20 |
