Dell Network Adapter
Quicklinx: 9ZFNWS00 Mfr#: 470-ABBT
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Fast Ethernet, Ethernet
Form Factor: External
Compatibility: PC
Type: Network adapter
More than 50 In Stock
£18.49 ex VAT
£22.18 inc VAT
The Dell USB 3.0 to Ethernet adapter enables you to add an Ethernet port to your computer or desktop using an existing USB input. Supporting up to Gigabit Ethernet data speeds, the adapter lets you enjoy faster streaming of online content, from news and live sports outlets to streaming radio and entertainment sites playing your favorite television shows and movies. The adapter contains a built-in driver for easy setup, eliminating the need to install drivers from a CD or download them from another source.
  • Adapter converts USB 3.0 to Ethernet
    For faster streaming and network connectivity, the Dell USB 3.0 to Ethernet adapter enables you to add an Ethernet port using an existing USB input on your computer or desktop. A handy addition for users looking to expand or add networks, the adapter lets you establish a connection or connect to another network without requiring a router or switch.
  • Ethernet adapter enables connectivity
    This simple, innovative Ethernet adapter from Dell allows you to extend your device's bandwidth by establishing an Internet connection. As long as your device is equipped with a USB input, this compact adapter ensures seamless results. Best of all, it doesn't require replacing or adding a network card. Use it to add another network, connect with another computer and enjoy videos and other streaming content faster.
  • Ensures fast streaming and downloads
    The Dell USB 3.0 to Ethernet adapter supports up to Gigabit Ethernet data speeds, so you can enjoy faster streaming of online content, from news and live sports outlets to streaming radio and entertainment sites playing your favorite television shows and movies.
  • Contains built-in driver for convenient setup
    The Dell USB 3.0 to Ethernet adapter contains a built-in driver for easy setup, eliminating the need to install drivers from a CD or download them from another source. The adapter saves you time by automatically prompting you to install the driver when you plug it in for the first time.
  • Compact size offers easy portability
    This lightweight adapter is easy to use and keep handy. The adapter is fitted with a USB A on one end and an RJ-45 on the other, a standard fit for a variety of compatible devices.
Dell - network adapter - USB 3.0 - Gigabit Ethernet x 1
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
2.03 cm x 15.2 cm x 1.52 cm
32 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
USB 3.0
1-year warranty
Network adapter
External
SuperSpeed USB 3.0
Ports
Wired
Cabling Type
USB powered
USB 3.0
1 x 1000Base-T - RJ-45
2.03 cm
15.2 cm
1.52 cm
32 g
Limited warranty - 1 year
9ZFN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
9ZFN C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
Protocol: Fast Ethernet
Protocol: Ethernet
Compatibility: PC
Brand: Dell
