Dell N3048P Switch L3 Managed 48 x 10/100/1000
Quicklinx: BTPQWS00 Mfr#: 210-ABOH
N-series is a family of energy-efficient and cost-effective 1GbE and 10GbE switches designed for modernizing and scaling network infrastructure. The Dell Networking N3000 series offers high-availability GbE switches for Layer 3 access or aggregation, providing easy-to-manage solutions.
The Dell Networking N3000 series has Power-over-Ethernet Plus (PoE+) without an external power supply. This allows you to attach devices with high power requirements (up to 30.8 watts) without running a separate power cable. PoE+ is particularly useful in older buildings where installing power to multiple, widespread locations can be prohibitively expensive.
  • Modernize your network
  • Deliver clean power to network devices with PoE+ support
  • Designed for efficiency
    Built to help keep operating costs down, the N3000 series can operate at temperatures up to 113°F (45°C) to help reduce cooling costs.
  • Advanced feature set to simplify management
    The Dell Networking N3000 series is designed for easy deployment, outstanding interoperability and a low learning curve for network administrators. A single OS release allows you to maintain consistent configurations across all N-series products with a comprehensive feature set.
  • Deploy with confidence at any scale
    With high throughput and capacity to handle unexpected workloads, the N3000 series switches are ideal Layer 3 solutions for fast growing GbE networks that require high-density aggregation with seamless redundancy and availability.
Dell Networking N3048P - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x 10 Gigabit SFP+ + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
Performance
Switching fabric bandwidth: 260 Gbps , Forwarding performance: 193 Mpps , Stacking bandwidth: 84 Gbps
MAC addresses: 16384 , IPv4 routes (static): 1024 , IPv6 routes (static): 1024 , IPv4 routes (dynamic): 8160 , IPv6 routes (dynamic): 4096 , Maximum member ports per LAG: 8 , Maximum dynamic ports per switch stack: 144 , LAG groups: 128 , OSPF routes: 8160 , RIP routes: 512 , ECMP next hops per route: 4 , ECMP groups: 64 , VLAN routing interfaces: 128 , VLANs supported: 4094 , Multicast entries (IPv4): 512 , Multicast entries (IPv6): 256 , ARP entries: 6144 , NDP entries: 400 , ACL: 100 , Maximum rules per ACL: 1023 , Max ACL rules system-wide: 4096 , Maximum ACL rules per interface (IPv4) egress rules: 1024 , Maximum ACL rules per interface (IPv4) ingress rules: 3072 , Maximum ACL rules per interface (IPv6) egress rules: 512 , Maximum ACL rules per interface (IPv6) ingress rules: 1021 , Maximum VLAN interfaces with ACLs applied: 24
MAC Address Table Size
16K entries
Routing Protocol
OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, OSPFv3, MLDv2, MLD
Remote Management Protocol
SNMP 2, SNMP, RMON, HTTP, SSH
Layer 3 switching, Layer 2 switching, MDI/MDI-X switch, auto-negotiation, port mirroring, stackable, Broadcast Storm Control, Multiple Spanning Tree Protocol (MSTP) support, Per-VLAN Rapid Spanning Tree (PVRST), Energy Efficient Ethernet, Dynamic VLAN Support (GVRP), dual firmware images, Network Access Control (NAC), tagged VLAN, redundant fans, Protocol-based VLANs support
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3az
Power Redundancy
Optional
43.4 cm x 40.7 cm x 4.35 cm
6.9 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
16K entries
Routing Protocol
Encryption Algorithm
MD5, AES, SSL, TLS
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
1 GB
Flash Memory
256 MB
48 x Gigabit LAN RJ-45 , 2 x 10Gbit LAN SFP+ , 2 x Gigabit LAN , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Provided
1100 Watt
FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, EAC, CCC Class A
43.4 cm
40.7 cm
4.35 cm
6.9 kg
Limited warranty - lifetime
50 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
BTPQ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
