N-series is designed for modernizing and scaling network infrastructure. The Dell Networking N3000 series offers high-availability GbE switch for Layer 3 access or aggregation, providing easy-to-manage solutions.
Built to help keep operating costs down, the N3000 series can operate at temperatures up to 113°F (45°C) to help reduce cooling costs.
Modernize your network
N-series is designed for modernizing and scaling network infrastructure. The Dell Networking N3000 series offers high-availability GbE switch for Layer 3 access or aggregation, providing easy-to-manage solutions. -
Designed for efficiency
Built to help keep operating costs down, the N3000 series can operate at temperatures up to 113°F (45°C) to help reduce cooling costs. -
Advanced feature set to simplify management
The Dell Networking N3000 series is designed for easy deployment, outstanding interoperability and a low learning curve for network administrators. -
Deploy with confidence at any scale
With high throughput and capacity to handle unexpected workloads, the N3000 series switch is an ideal Layer 3 solution for fast growing GbE networks that require high-density aggregation with seamless redundancy and availability.
- Dell Networking N3024F - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x Gigabit SFP + 2 x 10 Gigabit SFP+ + 2 x combo 1000Base-T
- Performance
- Switching fabric bandwidth: 212 Gbps , Forwarding performance: 158 Mbps , Stacking bandwidth: 84 Gbps
- Capacity
- MAC addresses: 16384 , Static routes: 1024 , OSPF routes: 8160 , RIP routes: 512 , Virtual interfaces (VLANs): 128 , IPv4 routes (Multicast): 1536 , IPv6 routes (Multicast): 512 , ARP entries: 6144 , NDP entries: 400 , ACL entries: 100 , ACL rules: 4096
- MAC Address Table Size
- 16K entries
- Routing Protocol
- OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, OSPFv3, MLDv2, MLD
- Remote Management Protocol
- SNMP 2, SNMP, RMON, HTTP, SSH
- Flow control, Layer 3 switching, Layer 2 switching, MDI/MDI-X switch, auto-negotiation, VLAN support, port mirroring, stackable, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), port forwarding, STP Root Guard, LLDP support, Link Aggregation Control Protocol (LACP), Energy Efficient Ethernet, dual firmware images, Network Access Control (NAC), tagged VLAN, Generic VLAN Registration Protocol (GVRP)
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power Redundancy
- Optional
- 43.4 cm x 40.7 cm x 4.35 cm
- 6 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- Routing Protocol
- Encryption Algorithm
- MD5, AES, SSL, TLS
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 1 GB
- Flash Memory
- 256 MB
- 24 x Gigabit LAN SFP , 2 x 10Gbit LAN SFP+ , 2 x Gigabit LAN RJ-45 , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Provided
- 200 Watt
- 67.1 Watt
- 43.4 cm
- 40.7 cm
- 4.35 cm
- 6 kg
- Limited warranty - lifetime
- 0 °C
- 45 °C
- 0 - 95%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 65 °C
- Humidity Range Storage
- 0 - 85%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
