Dell N3024 Switch L3 Managed 24 x 10/100/1000
Quicklinx: BTPGWS00 Mfr#: 210-ABOD
Dell Networking N3024 are an energy-efficient and cost-effective switches designed for modernizing and scaling network infrastructure. N3024 switches utilize a comprehensive enterprise-class Layer 2 and Layer 3 feature set, deliver consistent, simplified management and offer high-availability device and network design. The N3024 switches offer a power-efficient and resilient Gigabit Ethernet (GbE) switching solution with integrated 10GbE uplinks for advanced Layer 3 distribution for offices and campus networks. The N3024 switches have high-performance capabilities and wire-speed performance utilizing a non-blocking architecture to easily handle unexpected traffic loads. Use dual internal hot-swappable 80PLUS-certified power supplies for high availability and power efficiency. The switches offer simple management and scalability via an 84Gbps (full-duplex) high availability stacking architecture that allows management of up to 12 switches from a single IP address.
  • Deliver clean power to network devices with PoE+ support
    The Dell Networking N3024 has 24 ports of Power-over-Ethernet Plus (PoE+) without an external power supply. This allows you to attach devices with high power requirements without running a separate power cable. PoE+ is particularly useful in older buildings where installing power to multiple, widespread locations can be prohibitively expensive.
  • Designed for efficiency
    Built to help keep operating costs down, the N3024 can operate at temperatures up to 113°F (45°C) to help reduce cooling costs. Features designed to improve overall efficiency.
  • Advanced feature set to simplify management
    The Dell Networking N3024 switch is designed for easy deployment, outstanding interoperability and a low learning curve for network administrators. A single OS release allows you to maintain consistent configurations across all N-Series products with a comprehensive feature set.
  • Deploy with confidence at any scale
    With high throughput and capacity to handle unexpected workloads, the N3024 switches are ideal Layer 3 solutions for fast growing GbE networks that require high-density aggregation with seamless redundancy and availability.
Dell Networking N3024 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x 10 Gigabit SFP+ + 2 x combo Gigabit SFP
Performance
Switching fabric bandwidth: 212 Gbps , Forwarding performance: 158 Mbps , Stacking bandwidth: 84 Gbps
MAC addresses: 16384 , Static routes: 1024 , OSPF routes: 8160 , RIP routes: 512 , Virtual interfaces (VLANs): 128 , IPv4 routes (Multicast): 1536 , IPv6 routes (Multicast): 512 , ARP entries: 6144 , NDP entries: 400 , ACL entries: 100 , ACL rules: 4096
MAC Address Table Size
16K entries
Routing Protocol
OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, OSPFv3, MLDv2, MLD
Remote Management Protocol
SNMP 2, SNMP, RMON, HTTP, SSH
Flow control, Layer 3 switching, Layer 2 switching, MDI/MDI-X switch, auto-negotiation, VLAN support, port mirroring, stackable, WRR queuing, Broadcast Storm Control, STP support, RSTP support, MSTP support, ACL support, QoS, port forwarding, STP Root Guard, LLDP support, LACP, Energy Efficient Ethernet, dual firmware images, NAC, tagged VLAN, GVRP
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3az
Power Redundancy
Optional
43.4 cm x 40.7 cm x 4.35 cm
6 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Routing Protocol
Encryption Algorithm
MD5, AES, SSL, TLS
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
1 GB
Flash Memory
256 MB
24 x Gigabit LAN RJ-45 , 2 x 10Gbit LAN SFP+ , 2 x Gigabit LAN SFP , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Provided
200 Watt
52.8 Watt
43.4 cm
40.7 cm
4.35 cm
6 kg
Limited warranty - lifetime
45 °C
0 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Humidity Range Storage
0 - 85%
BTPG C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
BTPG C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
