Dell N2024P Switch L2+ Managed 24 x 10/100/1000
Quicklinx: BTP9WS00 Mfr#: 210-ABNW
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
POE: PoE+
Hurry, only 2 left in stock!
£985.76 ex VAT
£1,182.91 inc VAT
Dell Networking N2000 is a series of energy-efficient and cost-effective switches designed for modernizing and scaling network infrastructure. N2000 switches utilize a comprehensive enterprise-class Layer 2+ feature set, deliver consistent, simplified management and offer high-availability device and network design. The N2000 switch series offers a power-efficient Gigabit Ethernet (GbE) network-access switching solution with integrated uplinks. The N2000 switch series has high-performance capabilities and wire-speed performance, utilizing a non-blocking architecture to easily handle unexpected traffic loads. The switches offer simple management and scalability via a (full-duplex) high - availability stacking architecture that allows management of up to 12 switches from a single IP address. An integrated power supply and features such as Energy-Efficient Ethernet and short cable detection provide energy efficiency to help decrease power and cooling costs.
  • Modernize campus network architectures
    Modernize campus network architectures with a power-efficient and resilient switching solution with Power over Ethernet Plus (PoE+).. For greater interoperability in multivendor networks, all N-Series switches offer the latest open-standard protocols and include technology to interface with Cisco protocol RPVST+ and devices using CDP. Achieve high availability and full bandwidth utilization with Multi-chassis Link Aggregation (MLAG). All N-Series switches support MLAG to create active/active loop-free redundancy without spanning tree.
  • Leverage familiar tools and practices
    All N-Series switches include Dell Networking OS, designed for easier deployment, greater interoperability and a lower learning curve for network administrators. One common command line interface (CLI) and graphic user interface (GUI) using a well-known command language gets skilled network administrators productive quickly. This allows network administrators to maintain consistent configurations by running one OS release across all N-Series products. With USB auto-configuration, network administrators can rapidly deploy mirrored configurations to numerous devices by simply inserting a USB key.
  • Deploy with confidence at any scale
    N2000 series switches help create performance assurance. Scale easily with built-in rear stacking ports. Switch stacks can be managed from a single screen using the highly-available stacking architecture for high-density aggregation with seamless redundant availability.
Dell Networking N2024P - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
Performance
Switching fabric bandwidth: 172 Gbps , Forwarding performance: 128 Mpps , Stacking bandwidth: 84 Gbps
Virtual interfaces (VLANs): 4096 , ARP entries: 1024 , NDP entries: 400 , Priority queues per port: 8 , IPv4 routes (static): 256 , IPv6 routes (static): 128 , IPv4 routes (dynamic): 256 , VLAN routing interfaces: 256 , ACL: 100 , Max ACL rules system-wide: 2048 , Maximum rules per ACL: 1023 , Maximum ACL rules per interface (IPv4) ingress rules: 1024 , Maximum ACL rules per interface (IPv4) egress rules: 512 , Maximum ACL rules per interface (IPv6) ingress rules: 512 , Maximum ACL rules per interface (IPv6) egress rules: 256 , Maximum VLAN interfaces with ACLs applied: 24 , Maximum aggregation groups: 128 , Maximum dynamic ports per switch stack: 144 , Maximum member ports per LAG: 8
MAC Address Table Size
8192 entries
Routing Protocol
RIP-1, RIP-2, static IPv4 routing, static IPv6 routing
Remote Management Protocol
Telnet, TFTP
Flow control, auto-negotiation, VLAN support, port mirroring, DiffServ support, Broadcast Storm Control, IPv6 support, Access Control List (ACL) support, front to back airflow, IPv4 support, Energy Efficient Ethernet, Management Information Base (MIB), dual firmware images, Neighbor Discovery Protocol (NDP), redundant fans
44 cm x 38.7 cm x 4.35 cm
6.37 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
8192 entries
Routing Protocol
Telnet, TFTP
Encryption Algorithm
MD5, AES, SSL, TLS
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
1 GB
Flash Memory
256 MB
24 x Gigabit LAN RJ-45 PoE+ - 30.8 W , 2 x 10Gbit LAN SFP+ , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
Internal power supply
Installed Qty
1
Power Provided
1000 Watt
42.9 Watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Included
FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, VCCI Class A, EAC, CCC Class A
44 cm
38.7 cm
4.35 cm
6.37 kg
Limited warranty - lifetime
45 °C
0 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Humidity Range Storage
0 - 85%
BTP9 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
BTP9 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.13
BTP9 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.45
Ports: 24
Managed: Yes
POE: PoE+
Brand: Dell
Price Range Ex VAT: 750 - 1000
