The Dell Wired Keyboard provides a convenient keyboard solution for everyday home or office computing uses. The keyboard's full layout with chiclet style keys allows for efficient, comfortable typing - excellent for everyday usage on virtually any task at hand.
Wired keyboard for everyday home or office use
The Dell Wired Keyboard provides a convenient keyboard solution for everyday home or office computing uses. The keyboard's full layout with chiclet style keys allows for efficient, comfortable typing - excellent for everyday usage on virtually any task at hand. -
Multimedia keys for quick actions and commands
The convenient multimedia keys let you easily access functions such as play, pause, rewind, and fast-forward plus volume control. -
Comfortable, desk-centric design
With a compact design that still features a full-sized keyboard and number pad, the Dell Wired Keyboard is ideal for home and office environments. With a durable build and quiet keys, it's designed to provide comfort for the everyday demands of desktop usage. The Dell Wired Keyboard also has a palm rest that is available for separate purchase.
- Dell KB216 - keyboard - QWERTY - UK - white
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Volume, mute, play/pause, backward, forward
- Keys Style
- Chiclet
- White
- 44.2 cm x 12.7 cm x 2.44 cm
- 503 g
- 1-year warranty
- Designed For
- Inspiron 3459; Latitude 12 Rugged Tablet 7202, 14 Rugged Extreme (7404), 3150, 3310 2-in-1, 3340, 3450, 3480, 3550, 3580, 7390 2-in-1, E5450, E5550, E7250, E7450; OptiPlex 3020, 3030, 9020, 9030; Precision 3510, 5510, 7510, 7710, M2800, M3800, M4800, M6800; Vostro 3905
- Keyboard
- Interface
- USB
Input Device
- Hot Keys Function
- Keys Style
- Chiclet
- QWERTY UK
- 44.2 cm
- 12.7 cm
- 2.44 cm
- 503 g
- White
- Cables Included
- 1 x USB cable
- Limited warranty - 1 year
- Designed For
- Dell Inspiron 3459 , Dell Latitude 12 Rugged Tablet 7202, 14 Rugged Extreme (7404), 3150, 3310 2-in-1, 3340, 3450, 3480, 3550, 3580, 7390 2-in-1, E5450, E5550, E7250, E7450 , Dell OptiPlex 3020, 3030, 9020, 9030 , Dell Precision 3510, 5510, 7510, 7710, M2800, M3800, M4800, M6800 , Dell Vostro 3905
