Seamlessly connect up to three devices with this premium keyboard. The dual mode RF 2.4 GHz and Bluetooth 5.0 connectivity lets you effortlessly switch across devices with the connection-mode key on your keyboard.
Flexible multi-tasking
Seamlessly connect up to three devices with this premium keyboard. The dual mode RF 2.4 GHz and Bluetooth 5.0 connectivity lets you effortlessly switch across devices with the connection-mode key on your keyboard. -
Well-crafted design
The thoughtfully designed quiet keyboard is slim and stylish with a premium feel. The adjustable tilt legs on your keyboard give you the flexibility to work in your ideal typing position. -
Durable and secure
Powered by a good battery lives, the Dell Multi-Device wireless keyboard has been rigorously tested to work seamlessly with your Dell system. The keyboard offers 128-bit AES (Advanced Encryption Standard) encryption protecting your data transmission across your devices, providing you with a secure connection while typing.
- Dell Multi-Device KB700 - keyboard - QWERTY - UK - grey Input Device
- Keyboard
- Interface
- 2.4 GHz, Bluetooth 5.0
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- QWERTY UK
- Numeric Keypad
- Grey
- 43.33 cm x 12.15 cm x 2.836 cm
- 654 g
- Bundled Services
- 3 years NBD Advance Exchange
- Keyboard
- Interface
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
- Bundled Services
- Wireless
- QWERTY UK
- Numeric keypad
- 43.33 cm
- 12.15 cm
- 2.836 cm
- 654 g
- Grey
- Included Accessories
- 2 AAA batteries
- AES-128
- OS Required
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Android, Apple MacOS, FreeDOS, Google Chrome OS, Red Hat Enterprise Linux 8.0, Ubuntu Linux 18.04
- AAA type
- Installed Qty
- 2
- 0 °C
- 40 °C
- 95% RH (non-condensing)
