Dell MS5120W Mobile Pro Wireless Mouse
Quicklinx: GQC7WS00 Mfr#: MS5120W-GY
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wireless
Colour: Titan grey
Compatibility: PC
27 In Stock
£26.00 ex VAT
£31.20 inc VAT
The dual-mode connectivity incorporates a 2.4GHz wireless and a Bluetooth 5.0 connection so you can pair and connect to almost any PC via your preferred mode.
A 1600 DPI sensor ensures this Dell Mobile Pro Wireless Mouse - MS5120W handles high-resolution screens easily. Its optical sensor offers accurate tracking and is ideal on most desk surfaces.
  • Connect seamlessly
  • Easy pairing
    Pair your mouse to your Windows laptop via Bluetooth instantly using Microsoft Swift Pairi, so you do not need to configure in Windows settings every time. This mouse is also compatible with a variety of operating systems.
  • Built to last
    Work for up to 36 months on a single battery - that's three times longer than previous-generation models - and forget about having to recharge daily, weekly or even monthly. This lets you get on with your tasks smoothly without having to be concerned with battery replacements.
  • Precise tracking
  • Quick access
    Intuitively positioned shortcut buttons allow easy navigation across web pages and applications. Browse back and forth efficiently between pages onscreen effortlessly.
  • Simple management
    The Dell Peripheral Manager lets you customize and manage your keyboards and mice. Pair your devices, program shortcut buttons for quick access to your preferred applications and functions, and get battery and connectivity status and the latest firmware updates - whatever suits your business needs.
Dell MS5120W - mouse - 2.4 GHz, Bluetooth 5.0 - titan grey
Mouse
Wireless - 2.4 GHz, Bluetooth 5.0
Bundled Services
3 years NBD Advance Exchange
Titan grey
6.1 cm x 10.4 cm x 3.81 cm
73.7 g
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
1600 dpi
Swift Pair
AA type
Linux, Android, Google Chrome OS, Microsoft Windows 7 / 8 / 8.1 / 10
Mouse
Bundled Services
6.1 cm
10.4 cm
3.81 cm
73.7 g
Titan grey
Input Device
Wireless
Optical
Buttons Qty
7
Movement Resolution
1600 dpi
Swift Pair
1 AA battery
AA type
Run Time (Up To)
36 months
Type: Mouse
Colour: Titan grey
Compatibility: PC
Brand: Dell
