Dell MS116 Mouse Optical Wired USB Black For Lattitude
Quicklinx: BXTCWS00 Mfr#: 570-AAIS
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
19 In Stock
£8.69 ex VAT
£10.42 inc VAT
The Dell optical mouse - MS116 features optical LED tracking and wired connectivity providing a stellar performance day after day. Improve your productivity at the office or at home - the Dell optical mouse will help keep you on task with accurate 1000 DPI optical tracking.
  • Reliable performance day after day
  • Comfort that lasts
    Designed for comfortable use over extended periods of time, the Dell optical mouse is your desktop partner. Shaped and sized to fit the contours of your hand with 2 buttons and a scroll wheel, the Dell optical mouse makes it easy to navigate through on - screen projects.
  • Compatible with practically any system
    The Dell optical mouse is compatible with almost any system that has a USB port. Use one mouse in the office and keep another at home.
  • Plug and play convenience
    Simply plug the Dell optical mouse into any available USB port and get to work - it's that easy.
  • At home or in the office
    The Dell optical mouse is the perfect choice for either home or office use - wherever reliability, comfort and convenience are objectives.
  • Contemporary aesthetic
    With a contemporary design aesthetic, the Dell optical mouse - MS116 seamlessly fits into any desktop environment.
Dell MS116 - mouse - USB - black
Mouse
Wired - USB
413 g
Movement Detection Technology
Optical
Buttons Qty
2
Movement Resolution
1000 dpi
Cable Length
1.8 m
1-year warranty
Mouse
413 g
Input Device
Wired
USB
Optical
Buttons Qty
2
Movement Resolution
1000 dpi
Cable Length
1.8 m
1 x USB
Limited warranty - 1 year
Type: Mouse
Colour: Black
Compatibility: PC
Brand: Dell
