Dell Mini Display Port-to-Display Port Adapter - 20.3cm
Quicklinx: BF65WS00 Mfr#: 470-13627
The Dell Mini DisplayPort to DisplayPort adapter lets you view video content from any desktop or laptop with Mini DisplayPort video output on a variety of DisplayPort compliant displays. Compliant with DisplayPort specifications version 1.1a and supporting a maximum video resolution of 2058 x 1600 pixels, this versatile adapter ensures a quality viewing experience on everything from monitors to projectors.
  • Adapter converts Mini DisplayPort to DisplayPort
  • Display mobile content on the big screen
    This adapter allows you to take video content from your desktop or laptop and display it on any monitor, projector or HDTV featuring DisplayPort input. As long as your device is equipped with a mini DisplayPort output, this compact adapter ensures seamless conversion. Use it to enjoy movies on a home projector, mirror your desktop for an expanded workstation or show presentations at school or work.
  • Enjoy crystal-clear video
    The Dell Mini DisplayPort to DisplayPort adapter supports resolution of up to 2058 x 1600 pixels to provide crisp, rich video.
  • Compact size offers easy portability
    The adapter is fitted with a 20-pin Mini DisplayPort on one end and a DisplayPort on the other, a standard fit for a wide variety of DisplayPort-compatible display monitors, projectors and HDTVs.
  • DisplayPort-compliant for optimum picture quality
    The adapter is compliant with DisplayPort specification version 1.1a, ensuring true DisplayPort quality when video content is adapted and viewed. DisplayPort 1.1a specifications allow there to be a longer reach between source and display without reducing picture quality.
Dell Mini DisplayPort-to-DisplayPort - DisplayPort adapter - 20.3 cm
DisplayPort adapter
Length
20.3 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - female
DisplayPort adapter
Length
20.3 cm
Connector
20 pin DisplayPort - female
DisplayPort 1.1a
