Product
Dell Main Battery Pack 7.4V 6900mAh 51Wh
Quicklinx: BXDCWS00 Mfr#: CBP3478A
Stock Status: In Stock, Used Stock
More than 50 in stock
£44.86 ex VAT
£53.83 inc VAT
Standard delivery Delivered within 3-5 working days
2-Power Main Battery Pack - 1 x lithium polymer 6900 mAh - for Dell Latitude E5550.
2-Power Main Battery Pack - laptop battery - Li-pol - 6900 mAh
Laptop battery
Lithium polymer - 6900 mAh
Batteries Qty
1
1 year warranty
Dell Latitude E5550
Laptop battery
Quantity
1
Lithium polymer
Voltage Provided
7.4 V
6900 mAh
Limited warranty - 1 year
Dell Latitude E5550
Dell Main Battery Pack 7.4V 6900mAh 51Wh Bundle deal on Dell Main Battery Pack 7.4V 6900mAh 51Wh
£139.87
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: BXDC 034746
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not present or functional  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not present or functional  £6.29
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Dell
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
