Get down to business with the beautifully designed, thin and light Ultrabook! The Latitude 14 has elite and durable design - with soft- touch paint finish on the exterior, and a Tri-metal chassis magnesium alloy underneath the surface, the Latitude 7000 series is designed to survive challenging physical environments and MIL-STD 810G testing.
Elite connectivity experience
As with the previous generation, Dell Latitude 7000 Series is the only Ultrabook designed to be compatible with an existing laptop family docking station. -
The world's most secure business Ultrabook
Dell Data Protection | Encryption protects your data across all endpoints, including external media and in public cloud storage. -
Outstanding reliability you can trust
Latitude 12 7000 Series Ultrabook has been subjected to MIL-STD 810G testing to ensure durability under extreme conditions. A spill-proof keyboard protects against liquid damage.
- Dell Latitude E7450 - 14" - Intel Core i5 - 5300U - vPro - 8 GB RAM - 256 GB SSD
- Product Type
- Ultrabook
- Operating System
- Win 7 Pro 64-bit + Windows 8.1 Pro 64-bit Licence
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (5th Gen) - 5300U / 2.3 GHz, up to 2.9 GHz / 3 MB Cache
- Memory
- 8 GB DDR3L
- Storage
- 256 GB SSD
- Display
- 14" WLED touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 5500
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth, Wi-Fi, Gigabit Ethernet
- Battery
- 4-cell
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
- 33.7 cm x 23.15 cm x 2.04 cm
- 1.56 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - response time: next business day
- Product Type
- Ultrabook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5300U / 2.3 GHz
- Max Turbo Speed
- 2.9 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
Storage
- Main Storage
- 256 GB SSD
Display
- 14"
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 270 cd/m²
- Anti-fingerprint, Corning Gorilla glass NBT
Audio & Video
- Graphics Processor
- Camera
- Sound
- Speakers, microphone
Input
- Keyboard, touchpad
- Multi-touch touchpad
Communications
- Wireless
- Bluetooth, Wi-Fi
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell lithium polymer
- Capacity
- 54 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- 3 x USB 3.0 , LAN , Headphone/microphone combo jack , HDMI , Mini DisplayPort , Dock
- Memory Card Reader
- Yes (SD Card)
- Case Material
- Carbon fibre
- Dockable
- Security
- Free Fall Sensor, USB PowerShare technology, ExpressCharge, microphone with noise-cancellation
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- FIPS
- 1.56 kg
Sustainability Information
- ENERGY STAR Certified
