Count on powerful productivity packed in a sleek, versatile 14" design with best-in-class security and manageability.
The most secure business laptop is now sleeker and built with premium materials.
Structure-enhanced carbon fiber reinforced polymer cover, spill-proof keyboard and optional touch-screen display.
Anodized 180-degree hinge solution allows you to lay the monitor and keyboard flat on any surface.
Wireless freedom
Power up to two external displays and other peripherals. Intel Pro Wireless Display technology (Intel Pro WiDi) allows you to connect wirelessly and securely to projectors and displays. -
Quick compatibility
Connecting from your desk is always easy and secure with existing E-Dock family docking that allows quick integration into your office setup. Get down to business and connect to your peripheral devices without complication. -
Across-the-desk productivity
Anodized 180-degree hinge solution allows you to lay the monitor and keyboard flat on any surface. -
Enhanced design
- Dell Latitude E5470 - 14" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit + Windows 10 Pro 64-bit Licence - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR4 (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 14" WLED 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM) Security Chip, smart card reader
- Black
- 33.49 cm x 23.11 cm x 2.32 cm
- 1.76 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year - response time: next business day
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
Display
- 14"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Anti-glare, BFR/PVC-free
Audio & Video
- Graphics Processor
- Camera
- Sound
- Speakers, microphone
- Audio Features
- Output: noise-cancellation technology
Input
- Keyboard, touchpad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell lithium polymer
- Capacity
- 62 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , LAN , Headphone/microphone combo jack , HDMI , VGA
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial), Windows 10 Pro 64-bit recovery DVD
- Black
- Case Material
- Carbon fibre reinforced plastic
- Security
- Free Fall Sensor, USB PowerShare technology, ExpressCharge, microphone with noise-cancellation
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- FIPS 140-2, FIPS 201, TCG Certified
- Pricing Type
- 1.76 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
