Dell Latitude 9520 Intel Core i5-1135G7 16GB 256GB 15" Windows 10 Pro Grey
Quicklinx: GX1YWS00 Mfr#: 7RM1G
  • Core i5
  • IEEE 802.11n
UK/BTP/Lati 9520/Core i5-1135G7/8GB/256GB SSD/15.0" FHD/Intel Iris Xe/ThBlt & FgrPr & SmtCd & NFC/IR Cam/Mic/WLAN + BT/Backlit Kb/4 Cell/W10Pro+W11Pro Licence/3Y Basic Onsite.
  • Stunning from the start
    This Latitude is meticulously crafted with CNC aluminum, having the finest details of diamond cut edges and a hair-line brushed finish. The keyboard and touchpad feel as good as they look.
  • ExpressCharge 2.0
    Dell Optimizer extends runtime and improves battery performance by adapting to your patterns. ExpressCharge Boost delivers up to 35% charge within 20 minutes, or up to 80% charge within 40 minutes with ExpressCharge 2.0.
  • Count on your connection
    Intel Wi-Fi 6 delivers nearly 3x faster speeds and next-gen security to PCs and wireless networks.
Dell Latitude 9520 - 15" - Intel Core i5 - 1135G7 - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit + Windows 11 Pro Licence - Multilingual User Interface (MUI)
Intel Core i5 (11th Gen) - 1135G7 / 2.4 GHz, up to 4.2 GHz / 8 MB Cache
8 GB LPDDR4X (provided memory is soldered)
Storage
256 GB SSD - NVMe, Class 35
Display
15" 1920 x 1080 / Full HD @ 60 Hz - 147 ppi
Graphics
Intel Iris Xe Graphics
Keyboard Backlight
Integrated Webcam
NFC, 802.11a/b/g/n/ac/ax, Bluetooth 5.1
4-cell
Ambient light sensor, proximity sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Grey
34.02 cm x 21.58 cm x 1.484 cm
1.4 kg
Pricing Type
Build To Plan (BTP)
Environmental Standards
ENERGY STAR Qualified
Bundled Services
3 Years Basic Onsite
Notebook
Operating System
Windows 10 Pro 64-bit Edition + Windows 11 Pro Licence - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core i5 (11th Gen) 1135G7 / 2.4 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
8 MB
Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
LPDDR4X SDRAM
Speed
4266 MHz
Rated Speed
4266 MHz
Storage
Main Storage
256 GB SSD M.2 2230 PCIe 3.0 x4 - NVM Express (NVMe), Class 35
Display
15"
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
147
Image Aspect Ratio
16:9
Image Brightness
400 cd/m²
Colour Gamut
100% sRGB
Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, 35 ms response rate, 0.172 mm pixel pitch
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720 (standard), 640 x 360 (infrared)
Resolution
0.9 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
IR camera, RGB camera, 78 degrees, SafeShutter
Sound
Stereo speakers, quad array microphone
Codec
Realtek ALC714-CG
Waves MaxxAudio
Audio Features
Output: Smart Amp
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
4-cell lithium polymer
49 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
Interfaces Details
HDMI , 2 x USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial)
Grey
Integrated Options
Security
ExpressCharge, microphone with noise-cancellation
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
FIPS 140-2, halogen-free, FIPS 201, BFR-free, PVC-free
Pricing Type
Build To Plan (BTP)
1.4 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Bundled Services
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
GX1Y Dell Slim DW316 USB External DVD Drive In Stock £36.19
GX1Y Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £28.04
GX1Y Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £36.16
GX1Y Dell SB521A Magnetic Sound bar In Stock £30.78
GX1Y Dell MS5120W Mobile Pro Wireless Mouse In Stock £25.08
GX1Y Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £43.18
GX1Y Dell Dual Monitor Stand - MDS19 In Stock £109.85
