Versatile design. Exceptional experience. The Latitude 7490 is a business-class laptop built with premium materials.
Office everywhere
Latitude's superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you. -
Premium materials
The unibody design provides a clean and seamless exterior with superior structural performance. -
All-day power
Work confidently with a laptop equipped with all-day battery life and improvements to both web browsing and video playback time.
- Dell Latitude 7490 - 14" - Core i5 8250U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Optical Drive
- No optical drive
- Display
- 14" 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- Pointing stick
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 33.1 cm x 22.09 cm x 1.79 cm
- 1.4 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 3 years - response time: next business day
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD - (M.2 2280) PCIe
Display
- 14" - IPS
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare, ±80° horizontal viewing angle, ±80° vertical viewing angle, 157 ppi, 0.161 mm pixel pitch
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Resolution
- 0.92 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Fixed focus
- Sound
- Stereo speakers, array microphone
- Codec
- Realtek ALC3246
- High Definition Audio
Input
- Keyboard, touchpad, pointing stick
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell
- Capacity
- 60 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , USB-C/DisplayPort , LAN , HDMI , USB 3.1 Gen 1 (PowerShare)
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial)
- Black
- Case Material
- Magnesium alloy
- Security
- Noise reduction
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- FIPS 140-2, FIPS 201, TCG Certified
- Pricing Type
- 1.4 kg
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
Software applications
Bundle includes:
Microsoft Office Home & Business 2019 Box Pack (Medialess, 1 PC, One Time Purchase) worth £191.49 | in stock |
£1,147.23
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£1,063.24
Get more from your purchase from one of our essential accessories
Dicota Privacy filter 2-Way for Laptop 14" Wide (16:9), side-mounted | In Stock | £28.95 |
Dicota Privacy filter 4-Way for Laptop 14" Wide (16:9), self-adhesive | In Stock | £48.26 |
Dicota Privacy filter 2-Way for Laptop 14" Wide (16:9), self-adhesive | In Stock | £36.19 |
Dicota Privacy filter 4-Way for Laptop 14" Wide (16:9), side-mounted | In Stock | £48.26 |
Dicota Privacy filter 2-Way for Laptop 14" Wide (16:9), magnetic | In Stock | £51.51 |
