Set the pace of business with the Latitude 7400 2-in-1, featuring Dell powerful processors in a stunningly small design.
Premium inside and out
The machined aluminum finish and edge-to-edge glass is stunning in any setting and the anti-reflective, anti-smudge coating lets you see your screen in any light. -
Small and sleek
The Full HD display maximizes your view, while premium materials impress in any setting. -
Battery life that runs over multiple workdays
With hours of battery life, you can stay up to speed for the entire workday and then some.
- Dell Latitude 7400 2-in-1 - 14" - Core i5 8365U - vPro - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (8th Gen) 8365U / 1.6 GHz (4.1 GHz) / 6 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 14" touchscreen 1920 x 1080 / Full HD @ 60 Hz - 157 ppi
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Silver
- 31.977 cm x 19.99 cm x 1.489 cm
- 1.36 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Bundled Services
- 3 Years Basic Onsite
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 256 GB SSD M.2 PCIe
Display
- 14"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 157
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-reflective, anti-smudge, Wide Viewing Angle, 35 ms response rate, ±89° horizontal viewing angle, ±89° vertical viewing angle, 0.161 mm pixel pitch
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Resolution
- 0.3 Megapixel
- Video Resolutions
- 340 x 340
- Frame Rate
- 30 frames per second
- Camera Features
- IR camera, 2 x infrared emitters
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC3254
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560 - M.2 Card
- Technology
- 4-cell lithium polymer
- Capacity
- 52 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 20 V, 3.25 A
Connections & Expansion
- Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 (PowerShare) , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3) (Power Delivery) , HDMI
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Office (Trial)
- Silver
- Security
- Noise reduction
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- USB-C power adapter
- FIPS 140-2, TCG Certified
- Pricing Type
- 1.36 kg
Sustainability Information
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
- Shock Tolerance (operating)
- 105 g
- Shock Tolerance (non-operating)
- 40 g
- Vibration Tolerance (operating)
- 0.26 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.37 g @ RMS (random)
Dell Slim DW316 USB External DVD Drive | In Stock | £35.58 |
Dell MS116 Mouse Optical Wired USB Black For Lattitude | In Stock | £10.93 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £15.45 |
Dell KB216 Keyboard USB UK QWERTY Grey Inspiron 24 3459 | In Stock | £13.82 |
Dell Multimedia Keyboard KB216 UK | In Stock | £15.45 |
Dell E2020H 20" 1600 x 900 5ms VGA LED monitor | In Stock | £64.53 |
