Dell Latitude 7370 Core m7-6Y75 8GB 256GB SSD 13.3" Win 10 Pro
Quicklinx: CQVYWS00 Mfr#: 9C0JX
  • IEEE 802.11n
The world's smallest 13-inch business-class laptop with an InfinityEdge display. Featuring an aluminum or optional carbon fiber LCD back for incredible durability.
When you're at the forefront of ingenuity, you get noticed. That's why it's no surprise the Latitude 13 7000 Series was honored at the CES 2016 Innovation Awards. The winning streak continues.
Travel light and turn heads: The smallest business-class laptop in the world is incredibly thin and light so it's easy to carry with you comfortably. Get down to business anywhere duty calls with a slender and sophisticated PC that stays cool to the touch.
Made for gorgeous viewing: Magnify your experience with a breathtaking InfinityEdge display that virtually eliminates borders. Choose a Full HD (1920x1080) anti-glare screen and see for yourself how cleverly Dell fit a 13.3-inch screen into the frame of a 12-inch laptop.
The body of the Latitude 13 is crafted with layers of aerospace-grade carbon fiber and features an aluminum or optional carbon fiber LCD back for incredible durability. Plus, the commercial keyboards and touchpads are built to ISO standards to ensure maximum longevity and comfortable use.
Impressively efficient: Work at the speed of business with the latest 6th Gen Intel Core M processors with Intel VPro and Pro WiDi 6.0.
Leading-edge connectivity: Thunderbolt 3 multi-use port allows you to charge your laptop, connect to multiple devices (including Dell's new cable docking solutions) and enjoy data transfers up to 40Gbps, 8 times that of a USB 3.0.
Wireless technology: The new Latitude 13 is the first to use optional 4-antenna technology that fully enables WWAN - providing the most dependability and flexibility in communications.
Powered up longer: Count on excellent standard battery life, plus even more power to carry you through every meeting with the optional Dell Power Companion.
  • Travel light and turn heads
  • Made for gorgeous viewing
  • High-grade materials
    The body of the Latitude 13 is crafted with layers of aerospace-grade carbon fiber. Plus, Dell's commercial keyboards and touchpads are built to ISO standards to ensure maximum longevity and comfortable use.
  • Impressively efficient
  • Leading-edge connectivity
Dell Latitude 7370 - 13.3" - Intel Core m7 - 6Y75 - vPro - 8 GB RAM - 256 GB SSD - 4G LTE
Ultrabook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Platform Technology
Intel vPro Platform
Intel Core m7 (6th Gen) - 6Y75 / 1.2 GHz, up to 3.1 GHz / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
13.3" WLED touchscreen 3200 x 1800 / QHD+
Graphics
Intel HD Graphics 515
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
Wireless Broadband (WWAN)
4G LTE
4-cell
Security
Trusted Platform Module (TPM) Security Chip
30.48 cm x 21.05 cm x 1.432 cm
1.12 kg
Pricing Type
Build To Plan (BTP)
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 3 years - response time: next business day
Ultrabook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core m7 (6th Gen) 6Y75 / 1.2 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
256 GB SSD M.2 SATA
Display
13.3"
LCD Backlight Technology
WLED backlight
Touchscreen
Resolution
3200 x 1800 (QHD+)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
350 cd/m²
Anti-glare, Corning Gorilla glass NBT, Infinity Edge display
Audio & Video
Graphics Processor
Camera
Yes - HD
Camera Features
720p HD movie recording
Sound
Speakers, microphones
Input
Keyboard, touchpad
Keyboard Backlight
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Intel Wireless Display (WiDi), Miracast
Generation
4G
LTE
Controller
Dell Wireless 5811E
4-cell
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Slots
1 x Micro-SIM card
Interfaces Details
2 x USB-C (supports Thunderbolt 3) , Mini-HDMI , Headphone/microphone combo jack , USB 3.0
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft Office (Trial), Windows 10 Pro 64-bit recovery DVD
Case Material
Carbon fibre
Security
Dell Data Protection, microphone with noise-cancellation
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
FIPS 140-2, TCG Certified
Pricing Type
Build To Plan (BTP)
1.12 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
