Dell Latitude 7300 Core i7-8665U 16GB 512GB SSD 13.3" Win 10 Pro
Quicklinx: FP1QWS00 Mfr#: G3TXG
  • Core i7
  • IEEE 802.11n
Automatically join the strongest Wi-Fi connection available with ExpressConnect. Even without Wi-Fi, experience better streaming, downloading and video conferencing with up to 233% improvement in WWAN speeds gen over gen with the 1.0 Gbps. Stay connected with the first 4x4 dynamic antenna tuning solution in a PC that provides reliable mobile broadband, especially in weak signal areas. The extra two antennas act as additional "ears", resulting in up to 70% faster speeds. Dynamic antenna tuning enables global network coverage without needing to switch parts, and keeps the laptop small with narrow screen bezels.
Keep the work flowing with a high-density battery and ExpressCharge, which allows an 80% charge in one hour. With Dell Power Manager, you can choose between four modes to balance between optimal battery or power performance. Using the Super Low Power panel is 50% more efficient than standard FHD panels without compromising resolution, color or brightness.
With a 4-sided narrow border panel and antiglare screen, you'll be able to work better in front of the screen wherever you go.
  • Work anywhere
  • Power through the day
  • Improved screen
  • Seamless sign on
    SafeID protects end user credentials with optional fingerprint reader on the power button and Smart Card Reader, so you can work faster.
Dell Latitude 7300 - 13.3" - Intel Core i7 - 8665U - vPro - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Platform Technology
Intel vPro Platform
Intel Core i7 (8th Gen) - 8665U / 1.9 GHz, up to 4.8 GHz / 8 MB Cache
16 GB DDR4
Storage
512 GB SSD
Display
13.3" 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Silver
Image Colour Disclaimer
The displayed product image may be a different colour
30.65 cm x 20.695 cm x 1.845 cm
1.24 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
3 Years Basic Onsite
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 8665U / 1.9 GHz
Max Turbo Speed
4.8 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Intel Turbo Boost Technology 2.0
RAM
16 GB
Max RAM Supported
32 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
512 GB SSD M.2 PCIe
Display
13.3"
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
RGB camera
Sound
Stereo speakers, array microphone
Codec
Realtek ALC3254
High Definition Audio
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Multi-gesture touch pad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
4-cell Lithium Ion
60 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Interfaces Details
USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , HDMI , Headphone/microphone combo jack , USB-C 3.1 Gen 2 (supports Thunderbolt 3)
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Silver
Case Material
Aluminum
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.24 kg
Sustainability Information
TCO Certified
Bundled Services
10 - 90% (non-condensing)
Shock Tolerance (operating)
140 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
FP1Q Dell Slim DW316 USB External DVD Drive In Stock £36.19
FP1Q Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £7.34
FP1Q Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £11.98
