Dell Latitude 7290 Core i5-7300U 8GB 256GB SSD 12.5" Windows 10 Pro
Quicklinx: DC7PWS00 Mfr#: 4W72G
Display Size: 12.5in
Processor Model: I5-7300U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£790.83 ex VAT
£948.99 inc VAT
Latitude's superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you.
  • Premium materials
    The unibody design provides a clean and seamless exterior with superior structural performance. Finished with soft-touch paint.
  • Smooth and precise
    An upgraded Microsoft precision touchpad allows for improved gesture controls and swiping.
  • Built with stunning resolution
    The 12.5" HD screen produces lifelike visuals for remarkable viewing from every angle.
  • All-day power
    Work confidently with a laptop equipped with all-day battery life and improvements to both web browsing and video playback time.
  • Dell Thunderbolt dock
    Quickly connect your mobile workstation to a single data and power source for ultimate display performance and speedy data transfers.
Dell Latitude 7290 - 12.5" - Core i5 7300U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) 7300U / 2.6 GHz (3.5 GHz) / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB - M.2 2280 SSD
Optical Drive
No optical drive
Display
12.5" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
33.1 cm x 22.09 cm x 1.79 cm
1.4 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 3 years - response time: next business day
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Platform Technology
Intel vPro Technology
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2400 MHz - 2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD - (M.2 2280) SATA
Display
12.5" - TN
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
200 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Fixed focus
Sound
Stereo speakers, array microphone
Codec
Realtek ALC3246
High Definition Audio
Input
Keyboard, touchpad
Keyboard Backlight
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
4-cell lithium polymer
60 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , HDMI , USB-C/DisplayPort , LAN
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Case Material
Magnesium alloy
Security
Noise reduction
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
FIPS 140-2, TCG Certified
Pricing Type
1.4 kg
60 °C
10 - 90% (non-condensing)
Software applications
Dell Latitude 7290 Core i5-7300U 8GB 256GB SSD 12.5 Bundle deal on Dell Latitude 7290 Core i5-7300U 8GB 256GB SSD 12.5" Windows 10 Pro
£976.05
saving £8.33
£890.00
Optical Storage: None
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: Dell
Price Range Ex VAT: 750 - 1000
