The Latitude 12 7000 Series is the thinnest and lightest 12.5" business-class 2-in-1, designed to go wherever work takes you. With an innovative magnetic connection for quick one-handed transitions, it's always ready to flip into tablet mode at a moment's notice.
Enjoy stunning resolution with the 12.5" Ultrasharp 4K UHD display, optimized for intuitive touch interaction. Every Latitude 12 is constructed with premium materials, including magnesium alloy and edge-to-edge Corning Gorillas Glass NBT, and is finished off with soft-touch paint.
Easily interact with your own personal digital assistant, Cortana, equipped with MaxxAudio Pro by Waves for a natural voice collaborative experience.
Multitask effortlessly with 6th Gen Intel Core M processors and up to 8GB memory. The Latitude 12's two Type-C USB ports and multi-card reader allow you to conveniently link and customize your accessories.
Industry-leading SSD PCIe storage offers lighter weight storage and up to 4x faster data transfer speeds. Built-in wireless technology with the latest long-range 802.11 ac wireless technology makes it easy to surf, stream and stay connected, while the long battery life allows up to 8 hours of unplugged power.
Remarkably thin, fully flexible
The Latitude 12 7000 series is Dell's thinnest and lightest 12.5" business-class 2-in-1, designed to go wherever work takes you. With an innovative magnetic connection for quick one-handed transitions, it's always ready to flip into tablet mode at a moment's notice. -
Built to last
Every Latitude 12 is constructed with premium materials, including magnesium alloy and edge-to-edge Corning Gorillas Glass NBT, and is finished off with soft-touch paint. -
A helping hand
Easily interact with your own personal digital assistant, Cortana, equipped with MaxxAudio Pro by Waves for a natural voice collaborative experience. -
Link up easily
The Latitude 12's two Type-C USB ports and multi-card reader allow you to conveniently link and customize your accessories. -
Faster and lighter
Industry-leading SSD PCIe storage offers lighter weight storage and up to 4x faster data transfer speeds. -
Freedom to roam
Built-in wireless technology with the latest long-range 802.11 ac wireless technology makes it easy to surf, stream and stay connected, while the long battery life allows long hours of unplugged power.
- Dell Latitude 7275 - 12.5" - Intel Core m5 - 6Y57 - vPro - 4 GB RAM - 128 GB SSD
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core m5 (6th Gen) - 6Y57 / 1.1 GHz, up to 2.8 GHz / 4 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 128 GB SSD
- Display
- 12.5" touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 515
- Input Device
- Keyboard, touchpad
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac
- Battery
- 2-cell - up to 8 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Dimensions (WxDxH) - tablet
- 29.087 cm x 19.285 cm x 0.811 cm
- 730.7 g
- Pricing Type
- Build To Plan (BTP)
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 3 years - response time: next business day
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Intel Core m5 (6th Gen) 6Y57 / 1.1 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache, Intel Active Management Technology 11 (AMT 11)
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 128 GB SSD mSATA PCIe
Display
- 12.5"
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 360 cd/m²
- Anti-fingerprint, Corning Gorilla glass NBT, BFR/PVC-free
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 8 Megapixel (rear), 5 Megapixel (front)
- Sound
- Speaker, two microphones
- Audio Features
- Output: MaxxAudio Pro
Input
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Intel Wireless Display (WiDi), Miracast
- Technology
- 2-cell
- Capacity
- 30 Wh
- Run Time
- Up to 8 hours
- Battery Run Time
- Wireless on: up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 30 Watt
Connections & Expansion
- Interfaces Details
- 2 x Thunderbolt 3 , Headphone/microphone combo jack , Dock
- Memory Card Reader
- 3 in 1 (SDIO, microSD, microSDHC, microSDXC UHS)
Software
- Software Included
- Microsoft Office (Trial), Windows 10 Pro 64-bit recovery DVD
- Black
- Case Material
- Magnesium alloy
- Dockable
- Security
- Digital compass, Accelerometer, volume control, gyroscope, Dell Data Protection, ExpressCharge, arsenic free
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter, keyboard
- Cables Included
- USB-C 3.0 adapter
- FIPS 140-2, TCG Certified
- Pricing Type
- 730.7 g
- Dimensions (WxDxH) / Weight Details
- 29.087 cm x 19.285 cm x 0.811 cm / 730.7 g - tablet , 29.087 cm x 19.285 cm x 1.71 cm / 1.4052 kg - tablet with keyboard
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
