Dell Latitude 5580 Core i5-7200U 8GB 256GB 15.6" Win 10 Pro Black
Quicklinx: CQVNWS00 Mfr#: TX8F9
  • Core i5
  • IEEE 802.11n
A 15.6" laptop built for ultimate productivity and performance. Featuring top of the line security features and flexible docking options.
Log in with ease: Activate Windows Hello via optional infrared camera to facilitate facial recognition for easy and secure access.
Trusted authentication: The Latitude 5580 offers multiple security options to meet your diverse security needs. Features include essential multi-factor authentication hardware such as touch fingerprint reader, contacted FIPS 201 Smart Card Reader and Contactless Smart Card Reader NFC with Control Vault 2 Fips 140-2 Level 3 Certification to prevent unauthorized access.
Protection from attacks: Dell ControlVault provides a more secure alternative for storing and processing passwords, biometric templates and security codes.
Manage with ease: Through Dell unique vPro extensions, you can remotely manage a fleet of devices, including diagnostics whether they are powered on or off.
The power to perform: Leverage scalable performance using Intel's latest 7th Gen Core i Dual (U) or Quad Core (H) processors, NVIDIA graphics and a range of storage options from HDD to M.2 PCIe NVMe.
Designed with purpose: Work confidently on a laptop equipped with all-day battery life and if needed, bring your Dell Power Companion for an extended day.
Focus on work, not your notebook: Tested against 15 MIL STD 810G benchmarks, the incredibly durable systems make sure your work stays safe wherever you go.
Only Dell offers industry-leading encryption, authentication including optional touch fingerprint reader and leading-edge malware prevention from a single source right out of the box. Plus, with Dell Data Protection , Protected Workspace, your data is safe across all endpoints, including external media, self-encrypting drives and in public cloud storage.
The world's most manageable laptop is built to allow flexible and automated BIOS and system configurations through Dell Client Command Suite free tools. Dell makes it easy to deploy, monitor and update your Latitude fleet.
Features a durable, built-to-last chassis that has undergone extensive military-grade MIL-STD 810G testing that ensures your system can withstand real-world conditions.
  • Protection from attacks
  • Manage with ease
  • Designed with purpose
Dell Latitude 5580 - 15.6" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD
Display
15.6" 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Input Device
Pointing stick
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM) Security Chip, smart card reader
37.6 cm x 25.07 cm x 2.325 cm
1.9 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year - response time: next business day
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (7th Gen) 7200U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 SATA 6Gb/s
Display
15.6"
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Resolution
0.92 Megapixel
Sound
Stereo speakers, microphone
Codec
Realtek ALC3246
High Definition Audio
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
3-cell
AC Adapter
Input
(50/60 Hz)
Output
65 watt, 19.5 V, 3.34 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , 2 x USB 3.0 , USB 3.0 (PowerShare) , USB-C (supports DisplayPort Alt Mode) , LAN , HDMI , VGA
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial)
Security
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.9 kg
35 °C
10 - 90% (non-condensing)
