The small 14" mainstream business-class notebook lets you get to work faster than ever thanks to its scalable features, powerful performance and ExpressCharge.
Bypass passwords
Start the workday faster by signing on with an optional fingerprint reader integrated into the power button or with the optional IR camera + Windows Hello for seamless authentication. -
Power through the day
Keep the work flowing with a high-density battery and ExpressCharge, which allows an 80% charge in one hour. With Dell Power Manager, you can choose from four modes to balance between optimal battery or power performance. -
Connect anywhere
Seamlessly work on the go thanks to optional mobile broadband supporting speeds up to 450 Mbps. -
Travel light
The Latitude 5400 is more mobile and portable than ever, with an improved design that's thin and modern. The bottom mount keyboard contributes to its clean look and feel. -
Ultimate views
The display is packed with features designed to keep you focused on your work, like the four-sided narrow bezel and antiglare screen.
- Dell Latitude 5400 - 14" - Intel Core i5 - 8365U - vPro - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (8th Gen) - 8365U / 1.6 GHz, up to 4.1 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe, Class 35
- Display
- 14" WLED 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- Pointing stick
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- 32.305 cm x 21.6 cm x 2.085 cm
- 1.52 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 1 year - on-site
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8365U / 1.6 GHz
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2400 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - NVM Express (NVMe), Class 35
Display
- 14"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, Wide Viewing Angle
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Resolution
- 0.92 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- RGB camera
- Sound
- Stereo speakers, array microphone
- Codec
- Realtek ALC3204
- Wave MAXXAudio Pro
Input
- Keyboard, touchpad, pointing stick
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 68 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19.5 V
Connections & Expansion
- Interfaces Details
- 3 x USB 3.1 Gen 1 , LAN , HDMI , Headphone/microphone combo jack , USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode)
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Microsoft Office (30 days trial, excludes office licence)
- Security
- ExpressCharge
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- FIPS 140-2
- Pricing Type
- 1.52 kg
Sustainability Information
- TCO Certified
Dell Slim DW316 USB External DVD Drive | In Stock | £35.33 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £14.75 |
Dell E2020H 20" 1600 x 900 5ms VGA LED monitor | In Stock | £54.51 |
