Dell Latitude 5330 Intel Core i5-1235U 8GB 256GB 13.3" Windows 10 Pro Grey
Quicklinx: H40XWS00 Mfr#: 2YHGY
  • Core i5
  • IEEE 802.11n
Latitude 5330|i5-1235U, vPro|8GB|256GB SSD|13.3" FHD Touch 2-in-1|IR Cam & Mic|Intel Iris Xe|ThBlt|FgrPr|SmtCd|4 Cell|65W Type-C|WLAN|Backlit Kb|W10Pro+W11Pro Licence|1Y Basic Onsite.
  • ExpressConnect
    Be on 2 networks at once with simultaneous multi-network connection for faster data and video downloads. Get more data transfer from optimized networking, faster application data processing and better video quality from optimized Internet bandwidth.
  • 4G and Wi-Fi 6E connections
    Wi-Fi 6E allows more channels with more bandwidth which provides faster, smoother Wi-Fi, especially in high-density areas while 4G LTE options keep you connected wherever you work.
  • Work remote for longer
    Long battery life with ExpressCharge that provides charge quickly.
  • Intelligent privacy
    Onlooker detection notifies you when someone is peering at your screen and will texturize your screen. Look Away Detect knows when your focus is elsewhere and dims to further protect privacy and save battery life.
  • Enhanced camera
    Look great on every video call with improved Full HD IR camera options. Available Temporal Noise Reduction enhances image quality in any light.
  • ExpressSign-In
    A camera-based proximity sensor wakes your system on approach and locks when you walk away.
  • Intelligent audio
    Artificial intelligence improves audio and voice quality and adjusts for different environments. Neural Noise Cancellation eliminates unwanted background noise as well as the background noise of the participants on your call.
  • ExpressResponse
    Based on user behavior, ExpressResponse prioritizes your CPU to improve the performance of the apps you're currently using.
  • Cool under pressure
    Larger fan with optimized venting and other thermal improvements keeps your system cool even when working with multiple applications.
  • Easy on the eyes
    Featuring ComfortView Plus low blue light technology to reduce eye strain for all day working.
Dell Latitude 5330 - 13.3" - Intel Core i5 - 1235U - 8 GB RAM - 256 GB SSD
Notebook - flip design
Operating System
Win 10 Pro 64-bit (downgrade from Windows 11 Pro) + Windows 11 Pro Licence - Dutch / English / French / German / Italian
Intel Core i5 (12th Gen) - 1235U / 1.3 GHz, up to 4.4 GHz / 12 MB Cache
8 GB LPDDR4 (provided memory is soldered)
Storage
256 GB SSD - NVMe, Class 35
Display
13.3" touchscreen 1920 x 1080 / Full HD @ 60 Hz - 166 ppi
Graphics
Intel Iris Xe Graphics
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth
4-cell
Accelerometer
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Grey
30.57 cm x 20.75 cm x 1.843 cm
1.32 kg
Pricing Type
Build To Stock (BTS)
Manufacturer Selling Program
Dell Smart Selection
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Bundled Services
1 Year Basic Onsite
Operating System
Windows 10 Pro 64-bit Edition (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - Dutch / English / French / German / Italian
Processor / Chipset
CPU
Intel Core i5 (12th Gen) 1235U / 1.3 GHz
Max Turbo Speed
4.4 GHz
Number of Cores
10-core
Cache
12 MB
12 Threads
RAM
8 GB (provided memory is soldered)
LPDDR4 SDRAM
Speed
3200 MHz
Rated Speed
3200 MHz
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe), Class 35
Display
13.3"
Touchscreen
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
166
Image Aspect Ratio
16:9
Image Brightness
270 cd/m²
Colour Gamut
100% sRGB
Wide Viewing Angle, Corning Gorilla glass, ±85° horizontal viewing angle, ±85° vertical viewing angle, 35 ms response rate, 0.153 mm pixel pitch, anti-reflective, anti-smudge
Audio & Video
Graphics Processor
Camera
Yes - 1920 x 1080 (standard), 640 x 360 (infrared)
Resolution
2.07 Megapixel (standard), 0.23 Megapixel (infrared)
Image Sensor Type
CMOS
Video Resolutions
1920 x 1080
Frame Rate
30 frames per second
Camera Features
Privacy shutter, IR/RGB camera, 87.6 degrees, Temporal Noise Reduction
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6E AX 211 - M.2 2230
Dual stream (2x2)
4-cell Lithium Ion
58 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 watt, 5 / 9 / 15 / 20 V
Connections & Expansion
Interfaces Details
HDMI , 2 x USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (30 days trial, excludes office licence), Dell Applications for Windows 11
Grey
Integrated Options
Accelerometer
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
FIPS 140-2, FIPS 201
Pricing Type
1.32 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Bundled Services
1 Year Basic Onsite
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
H40X Dell Slim DW316 USB External DVD Drive In Stock £36.19
H40X Dell KB-813 Smart Card Reader In Stock £31.94
H40X Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £28.04
H40X Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £36.16
H40X Dell SB521A Magnetic Sound bar In Stock £30.78
H40X Dell MS5120W Mobile Pro Wireless Mouse In Stock £25.08
H40X Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £43.18
H40X Dell Dual Monitor Stand - MDS19 In Stock £109.85
