UK/BTS/Lati 5320/Core i7-1185G7/16GB/512GB SSD/13.3" FHD/Intel Iris Xe/ThBlt & SmtCd/Cam & Mic/WLAN + BT/Backlit Kb/4 Cell/W10Pro+W11Pro Licence/vPro/1Y Basic Onsite.
ExpressConnect
New ExpressConnect automatically joins the strongest access point in the office and directs bandwidth to critical applications, wherever you work. -
ExpressResponse
With Intel Adaptix Technology, prioritize your most important apps, so they open faster and perform better. -
ExpressSign-in
Get to work fast with Dell's PC proximity sensor enabled by Intel Context Sensing Technology that detects your presence to instantly wake and log you in via the IR camera and Windows Hello, all without lifting a finger. It locks when you walk away, so your work stays safer. -
ExpressCharge
Dell Optimizer extends runtime and improves battery performance by adapting to your patterns. ExpressCharge Boost delivers up to 35% charge in about 20 minutes, or up to 80% charge in an hour with ExpressCharge. -
Intelligent Audio
Collaborate like you're in the same room. Intelligent Audio enhances your audio quality and reduces background noises, so you can hear and be heard, creating a better conference experience for all. -
Take charge
Keep working with outstanding battery life plus intelligent settings to preserve power when you're running low. Choose from a 42WHr battery for lighter weight or a larger 63Whr battery for longer run time. Get longer battery life when you choose the Super Low Power panel, which consumes less power than a standard display without impacting the brightness of the screen. -
Connect confidently
Stay connected with up to 450 Mbps LTE mobile broadband speeds. Wi-Fi 6E allows 7 additional channels (in 6GHz band) for more bandwidth which provides faster, smoother Wi-Fi, especially in high-density areas. Travel with ease with eSIM technology that connects to more global carriers without having to switch SIM cards. -
Scale to your needs
There's nothing holding you back from your best work with scalable memory and storage, including up to 32GB DDR4 memory and up to 2TB of storage. Choose from backlit and non-backlit keyboard options. -
Ports for any purpose
Quickly connect to peripherals with a full range of available ports, including 2x Type-C Thunderbolt 4 that can power up to 2 4K displays, or 1 8K display and legacy ports like HDMI. -
Fast performance
Up to the latest 11th Gen Intel Core vPro processors offer businesses the performance, manageability, built-in security features, and stability of the Intel vPro Platform, the platform built for business. -
Protect your work
All the security options you expect in a 5000 including Fingerprint Reader in the power button, IR camera for Windows Hello facial login and Smart Card reader (contacted and NFC contactless).
- Dell Latitude 5320 - 13.3" - Intel Core i7 - 1185G7 - vPro - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit + Windows 11 Pro Licence - Multilingual User Interface (MUI)
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (11th Gen) - 1185G7 / 3 GHz, up to 4.8 GHz / 12 MB Cache
- Memory
- 16 GB DDR4 (provided memory is soldered)
- Storage
- 512 GB SSD - NVMe
- Display
- 13.3" WLED 1920 x 1080 / Full HD @ 60 Hz - 166 ppi
- Graphics
- Intel Iris Xe Graphics
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1
- Battery
- 4-cell
- Accelerometer
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Grey
- 30.57 cm x 20.75 cm x 1.696 cm
- 1.18 kg
- Pricing Type
- Build To Stock (BTS)
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition + Windows 11 Pro Licence - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Intel Core i7 (11th Gen) 1185G7 / 3 GHz
- Max Turbo Speed
- 4.8 GHz
- Number of Cores
- Quad-Core
- Cache
- 12 MB
- Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 3200 MHz
- Rated Speed
- 3200 MHz
Storage
- Main Storage
- 512 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
- 13.3"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 166
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, 35 ms response rate, 0.153 mm pixel pitch, Super Low Power Panel (SLP)
Audio & Video
- Graphics Processor
- Camera
- Image Sensor Type
- CMOS
- Frame Rate
- 30 frames per second
- Camera Features
- Privacy shutter, RGB camera
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3254
- High Definition Audio
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - M.2 2230
- Technology
- 4-cell lithium polymer
- Capacity
- 63 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
- Interfaces Details
- HDMI , 2 x USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Office (30 days trial)
- Grey
- Integrated Options
- Accelerometer
- Security
- ExpressCharge
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- USB-C power adapter
- FIPS 140-2, FIPS 201
- Pricing Type
- 1.18 kg
Sustainability Information
- TCO Certified
- Bundled Services
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 140 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
Dell Slim DW316 USB External DVD Drive | In Stock | £36.19 |
Dell MS116 Mouse Optical Wired USB Black For Lattitude | In Stock | £9.71 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £15.05 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £28.04 |
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £36.16 |
Dell SB521A Magnetic Sound bar | In Stock | £30.78 |
Dell MS5120W Mobile Pro Wireless Mouse | In Stock | £25.08 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £43.18 |
Dell Dual Monitor Stand - MDS19 | In Stock | £109.85 |
