Dell Latitude business-class 2-in-1 gives you the flexibility you want, with features like ExpressCharge you can charge up to 80% in one hour.
Work how you want
Use it like a tablet or like a laptop with the ISO-compliant keyboard. -
Connect anywhere
Seamlessly work on the go thanks to optional mobile broadband supporting speeds up to 450Mbps. -
Stay synced
Thanks to Modern Standby capability, you can resume work quickly when waking your system since Wi-Fi is running in the background. -
Power through the day
Keep the work flowing with a high-density battery and ExpressCharge, which allows an 80% charge in one hour. With Dell Power Manager, you can choose between four modes to balance between optimal battery or power performance. -
Get up and go
Start the workday faster by signing on with optional fingerprint reader integrated into the power button or with the optional IR camera + Windows Hello for seamless authentication. -
Elevated design
Starting at 3.15lbs., this small and light 2-in-1 has a 4-sided narrow bezel with edge-to-edge Gorilla Glass and a light, stylish finish. It also features an optional Thunderbolt 3 port for even more versatility. -
Sustainability
Dell is proactive in the fight against pollution by using recycled ocean-bound plastic in the packaging. -
Work fast, stay cool
The fan technology utilizes a Liquid Crystal Polymer material. This allows for the creation of thinner fan blades and provides maximum airflow for an overall cooler experience. -
Seamless sign on
SafeID protects end user credentials with optional fingerprint reader on the power button and the optional FIPS 201 Smart Card Reader delivering fast, multi-factor authentication you've come to expect from the world's most secure PC portfolio. -
Remotely manage
Dell unique vPro extensions can remotely manage and run diagnostics on a fleet of devices, whether they are powered on or off.
- Dell Latitude 5300 2-in-1 - 13.33" - Core i5 8265U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe, Class 40
- Display
- 13.33" touchscreen 1920 x 1080 / Full HD @ 60 Hz - 166 ppi
- Graphics
- Intel UHD Graphics 620
- Input Device
- Digitizer, digital pen
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Black
- 30.57 cm x 20.75 cm x 1.93 cm
- 1.42 kg
- Pricing Type
- Build To Stock (BTS)
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), Class 40
Display
- 13.33" - IPS
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 166
- Image Aspect Ratio
- 16:9
- Image Brightness
- 255 cd/m²
- Colour Gamut
- 72% NTSC
- Anti-reflective, ±80° horizontal viewing angle, ±80° vertical viewing angle, glass cover, 72% NTSC colour gamut
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Fixed focus, 78.6 degrees, RGB camera
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3254
- High Definition Audio
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, digitizer, touchpad, digital pen
- Active pen support
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Technology
- 3-cell Lithium Ion
- Capacity
- 42 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- USB 3.1 Gen 1 , USB-C 3.1 Gen 1 (PowerShare) , Headphone/microphone combo jack , HDMI , USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode)
- Memory Card Reader
- Yes (microSD)
- Black
- Security
- ExpressCharge
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.42 kg
- Bundled Services
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
- Shock Tolerance (operating)
- 140 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
Dell Network Adapter | In Stock | £15.91 |
Dell Slim DW316 USB External DVD Drive | In Stock | £35.58 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £15.45 |
Dell KB216 Keyboard USB UK QWERTY Grey Inspiron 24 3459 | In Stock | £13.82 |
Dell Multimedia Keyboard KB216 UK | In Stock | £15.45 |
Dell E2020H 20" 1600 x 900 5ms VGA LED monitor | In Stock | £64.53 |
