Dell Latitude 5300 Intel Core i5-8265U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: FDZ2WS00 Mfr#: 826VD
Display Size: 13.3in
Processor Model: I5-8265U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
More than 50 in stock
£765.67 ex VAT
£918.80 inc VAT
A 13" business-class notebook lets you get to work faster than ever thanks to its scalable features, powerful performance and ExpressCharge.
  • Room for every project
    There's nothing holding you back from your best work with scalable memory and storage.
  • Make connections
    Quickly connect to peripherals with a full range of available ports, including USB Type-C and legacy ports like HDMI and RJ-45.
  • Ultimate views
    The display is packed with features designed to keep you focused on your work, like the four-sided narrow bezel and antiglare screen.
Dell Latitude 5300 - 13.3" - Core i5 8265U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache /
8 GB DDR4
Storage
256 GB SSD NVMe
Optical Drive
No optical drive
Display
13.3" WLED 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
30.57 cm x 20.75 cm x 1.93 cm
1.24 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
SO-DIMM 260-pin
Storage
Main Storage
256 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Display
13.3"
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare, 100% sRGB colour gamut, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Fixed focus, 78.6 degrees, RGB camera
Sound
Stereo speakers, array microphone
Codec
Realtek ALC3254
High Definition Audio
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Multi-gesture touch pad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
60 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , Headphone/microphone combo jack , HDMI , USB-C 3.1 Gen 2/DisplayPort
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft Office (Trial)
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.24 kg
ENERGY STAR Certified
35 °C
10 - 80% (non-condensing)
Shock Tolerance (operating)
105 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
40 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.26 g @ RMS (random)
Vibration Tolerance (non-operating)
1.37 g @ RMS (random)
Software applications
Dell Latitude 5300 Intel Core i5-8265U 8GB 256GB SSD 13.3 Bundle deal on Dell Latitude 5300 Intel Core i5-8265U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
£864.84
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Dell
Price Range Ex VAT: 750 - 1000
