An easily managed laptop with superior security features critical for small and growing businesses, all in a durable, reliable and sleek design.
Office everywhere
Latitude's superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you. -
Enhanced data protection
Data security is key in protecting your business and employees. Endpoint security, advanced user authentication and data encryption software all work cohesively to safeguard your data from threats and hacks. -
Outstanding reliability
Your Latitude 3590 features a durable, built-to-last chassis that has undergone extensive testing to ensure your system can withstand real-world conditions. -
Power your workday
Fast processors deliver the power you need for optimal productivity. The superior memory boosts transfer rates while using less voltage, making your Latitude run faster and more efficiently.
- Dell Latitude 3590 - 15.6" - Core i5 7200U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Optical Drive
- No optical drive
- Display
- 15.6" 1920 x 1080 / Full HD - 141 ppi
- Graphics
- Intel HD Graphics 620
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 38 cm x 25.8 cm x 2.27 cm
- 2.02 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- TCO Certified Notebooks 5
- Limited warranty - 1 year - response time: next business day
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD - (M.2 2280) SATA
Display
- 15.6"
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Pixel Density (ppi)
- 141
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Resolution
- 0.92 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3246
- High Definition Audio
- Audio Features
- MaxxAudio Pro
Input
- Keyboard, touchpad
- Numeric Keypad
Communications
- Wireless
- Wireless Controller
- Atheros QCA61x4A - M.2 2230
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111HSD
- Miracast
- Technology
- 4-cell lithium polymer
- Capacity
- 56 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- Headphone/microphone combo jack , USB 3.1 Gen 1 (PowerShare) , USB 2.0 , HDMI , VGA , USB-C/DisplayPort (Power Delivery) , LAN
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Black
- Security
- ExpressCharge, MU-MIMO technology
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- FIPS 140-2, TCG Certified
- Pricing Type
- 2.02 kg
- TCO Certified
- 0 °C
- 35 °C
- 10 - 90%
