Dell Latitude 3540 - Intel Core i7 - 1355U / up to 5 GHz - Win 11
Quicklinx: HNQMWS00 Mfr#: RF8WD
Screen Size: 15.6in
Processor Model: I7-1355U
Operating System: Windows 11 Pro
Hard Drive Capacity: 256GB
Graphics: Intel Iris Xe Graphics
  • Core i7
  • IEEE 802.11n
£818.76 ex VAT
£982.51 inc VAT
SPL|Dell Latitude 3540|i7-1355U|16GB|256GB SSD|15.6" FHD |IR Cam & Mic|Intel Iris Xe|FgrPr|3 Cell|65W|WLAN|Backlit Kb|W11 Pro|1Y Basic Onsite.
  • Modern design to boost productivity
    Smaller, re-designed chassis featuring a better color and texture. Improved keyboard with durable, laser-etched key prints and longer key travel for enhanced comfort. Upgraded clickpad with improved feel for a better experience.
  • Created for combining forces
    Intelligent Audio removes background noise and echoes on both ends of the call, and Voice Quality Monitoring lets you know when your voice quality is poor.
  • Experience uncompromised connectivity
    Wi-Fi 6E ensures you're always connected to fast Internet speeds. ExpressConnect joins the best available network, prioritizes conferencing apps and delivers fast data and video downloads with the world's first simultaneous multi-network connection.
  • Confidently confidential
    Enhanced security features include optional fingerprint reader and Chassis Intrusion Detection for ultimate protection. Sign-in securely and effortlessly with the optional Windows Hello supported FHD-IR camera. Control your privacy and have peace of mind with the mechanical camera shutter and mic mute button right at your fingertips.
  • Looking good has never felt so good
    50% post-consumer recycled battery frame and LCD Bezel. 100% recycled and renewable packaging with multipack options for even less waste.
Dell Latitude 3540 - 15.6" - Intel Core i7 - 1355U - 16 GB RAM - 256 GB SSD
Notebook
Operating System
Win 11 Pro - Dutch / English / French / German / Italian
Intel Core i7 (13th Gen) - 1355U / 1.7 GHz, up to 5 GHz / 12 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
256 GB SSD - NVMe, Class 35
Display
15.6" 1920 x 1080 / Full HD @ 60 Hz - 141 ppi
Graphics
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
3-cell - up to 4 hours
Security
Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Grey
35.9 cm x 23.969 cm x 2.04 cm
1.81 kg
Environmental Standards
TCO Certified Notebooks 9
Limited warranty - 1 year
Bundled Services
1 Year Basic Onsite
Notebook
Operating System
Windows 11 Pro - Dutch / English / French / German / Italian
Processor / Chipset
CPU
Intel Core i7 (13th Gen) 1355U / 1.7 GHz
Max Turbo Speed
5 GHz
Number of Cores
10-core
Cache
L3 - 12 MB
12 Threads
RAM
16 GB (2 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM
Speed
3200 MHz
Rated Speed
3200 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 2230 PCIe 4.0 x4 - NVM Express (NVMe), Class 35
Display
15.6" - IPS
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
141
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Anti-glare, Wide Viewing Angle, ±85° horizontal viewing angle, ±85° vertical viewing angle, 35 ms response rate, 0.17925 mm pixel pitch
Audio & Video
Graphics Processor
Video System Features
Functions as Intel UHD graphics (for single-channel memory)
Camera
Yes - 1920 x 1080 (standard), 640 x 360 (infrared)
Resolution
2.07 Megapixel (standard), 0.23 Megapixel (infrared)
Image Sensor Type
CMOS
Video Resolutions
1920 x 1080
Frame Rate
30 frames per second
Camera Features
Privacy shutter, IR/RGB camera, Temporal Noise Reduction, 80 degrees, 86.6 degrees (IR camera)
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio, Wave MAXXAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6E AX 211 - M.2 2230
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111H-CG
Dual stream (2x2)
3-cell Lithium Ion
54 Wh
Run Time
Up to 4 hours
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 watt, 19.5 V, 3.34 A
Connections & Expansion
Interfaces Details
HDMI , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , 2 x USB 3.2 Gen 1 , USB 3.2 Gen 1 (PowerShare) , LAN , Headphone/microphone combo jack
Software
Software Included
Microsoft Office (30 days trial, excludes office licence)
Grey
Security
ExpressCharge, ExpressChargeBoost
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
FIPS 140-2, TCG Certified
1.81 kg
Sustainability Information
TCO Certified
- TCO Certified Notebooks 9
Bundled Services
1 Year Basic Onsite
35 °C
Shock Tolerance (operating)
140 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
HNQM Kensington Clicksafe Combination Lock - Security Cable In Stock £34.56
Warranty Packs (2)
Protect your investment by taking out one of our great value warranty packs
HNQM Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - Extended Service Agreement In Stock £40.11
HNQM Dell Upgrade from 1Y Basic Onsite to 3Y ProSupport - extended service agreement - 3 years - on-site In Stock £79.53
Other bundles (16)
HNQM Dell Slim DW316 USB External DVD Drive In Stock £36.19
HNQM Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £7.34
HNQM Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £11.98
HNQM Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £26.32
HNQM Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £36.16
HNQM Dell SB521A Magnetic Sound bar In Stock £28.80
HNQM Dell MS5120W Mobile Pro Wireless Mouse In Stock £25.08
HNQM Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £62.54
HNQM Dell Dual Monitor Stand - MDS19 In Stock £130.16
HNQM Dell Dell Pro KM5221W - Keyboard and mouse set - wireless In Stock £30.62
HNQM Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot In Stock £43.95
HNQM Dell WEBCAM - WB3023 In Stock £41.59
HNQM Dell Dell Mobile Wireless Mouse - MS3320W - Black In Stock £19.44
HNQM Dell Dell Speakerphone SP3022 In Stock £51.33
HNQM Dell UltraSharp 24" 1920 x 1080 5 ms IPS In Stock £175.52
HNQM Dell UltraSharp U4924DW 49" 5120x1440 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor In Stock £996.32
Screen Size: 15.6in
Brand: Dell
Price Range Ex VAT: £750 - £1000
