Dell Latitude 3520 Intel Core i5-1135G7 8GB 256GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: GDVFWS00 Mfr#: THY6R
  • Core i5
  • IEEE 802.11n
UK/BTS/Lati 3520/Core i5-1135G7/8GB/256GB SSD/15.6" FHD/Intel Iris Xe/Cam & Mic/WLAN + BT/Backlit Kb/4 Cell/W10Pro/1Y Basic Onsite.
  • Fast performance
    An 11th Gen Intel Core processor offers businesses the performance, manageability, built-in security features and stability of Intel and aligns to a future-proof roadmap.
  • Connect anywhere
    Seamlessly work on the go. The Intel Wi-Fi 6 capability provides reliable connectivity, fast speeds and next-gen security to PCs and wireless networks.
  • Ports for any purpose
    Compatible with more monitors and accessories, with a full range of available ports, including USB 3.2 Gen2x2 Type-C port and legacy ports like HDMI and RJ45.
  • Start quickly
    Start up instantly with a fingerprint reader built into the power button.
  • Upgraded keyboard
    The larger edge-to-edge keyboard, keycaps and 10% larger touchpad make typing and navigation easier than ever.
  • Enhanced display
    Gain a brighter view with a 250-nit Full HD display panel.
Dell Latitude 3520 - 15.6" - Intel Core i5 - 1135G7 - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (11th Gen) - 1135G7 / 2.4 GHz, up to 4.2 GHz / 8 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe
Display
15.6" 1920 x 1080 / Full HD @ 60 Hz - 141 ppi
Graphics
Intel Iris Xe Graphics
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.2, Gigabit Ethernet
4-cell
Grey
36.1 cm x 24.095 cm x 1.806 cm
1.79 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Basic Onsite
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (11th Gen) 1135G7 / 2.4 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
8 MB
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
3200 MHz
Rated Speed
3200 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe 3.0 x4 - NVM Express (NVMe)
Display
15.6"
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
141
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Full HD wide-viewing angle (WVA) anti-glare, ±80° horizontal viewing angle, ±80° vertical viewing angle, 25 ms response rate, 0.179 mm pixel pitch
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
78.6 degrees, RGB camera
Sound
Stereo speakers, microphone
Codec
Realtek ALC3204
High Definition Audio
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111H
4-cell
54 Wh
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Interfaces Details
HDMI , USB-C 3.2 Gen 2x2 (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , USB 2.0 , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial)
Grey
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.79 kg
Sustainability Information
TCO Certified
Bundled Services
1 Year Basic Onsite
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
GDVF Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - Extended Service Agreement In Stock £40.11
Other bundles (8)
GDVF Dell Slim DW316 USB External DVD Drive In Stock £36.19
GDVF Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £7.34
GDVF Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £11.98
GDVF Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £26.32
GDVF Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £36.16
GDVF Dell SB521A Magnetic Sound bar In Stock £28.80
GDVF Dell MS5120W Mobile Pro Wireless Mouse In Stock £25.08
GDVF Dell Dual Monitor Stand - MDS19 In Stock £124.85
