Dell Latitude 3510 i3-10110U 8GB 256GB 15.6" Win10P
Quicklinx: FZS3WS00 Mfr#: PCDRY
  • Core i3
  • IEEE 802.11n
UK/BTS/Lati 3510/i3-10110U/8GB/256GB SSD/15.6" FHD/Intel UHD/Cam & Mic/WLAN + BT/Backlit Kb/3 Cell/W10Pro/1Y Basic Onsite.
Dell Latitude 3510 - 15.6" - Intel Core i3 - 10110U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i3 (10th Gen) - 10110U / 2.1 GHz, up to 4.1 GHz / 4 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe
Display
15.6" 1920 x 1080 / Full HD @ 60 Hz - 141 ppi
Graphics
Intel UHD Graphics
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac Wave 2/ax, Bluetooth 5.1, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
Grey
36.14 cm x 24.785 cm x 1.797 cm
1.91 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Bundled Services
1 Year Basic Onsite
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core i3 (10th Gen) 10110U / 2.1 GHz
Max Turbo Speed
4.1 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
15.6"
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
141
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Colour Gamut
45% NTSC
Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, 25 ms response rate, 0.179 mm pixel pitch
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
RGB camera, 87 degrees
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111H
3-cell
40 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Interfaces Details
HDMI , USB-C 3.2 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , USB 2.0 , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial)
Grey
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.91 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Bundled Services
1 Year Basic Onsite
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
FZS3 Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - Extended Service Agreement In Stock £40.11
Other bundles (5)
FZS3 Dell Slim DW316 USB External DVD Drive In Stock £36.19
FZS3 Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £9.71
FZS3 Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £15.05
FZS3 APC BACK-UPS BE650G2-UK 650VA 230V In Stock £107.44
FZS3 APC BACK-UPS BE850G2-UK 850VA 230V USB In Stock £119.38
