UK/BTS/Lati 3410/Core i5-10210U/8GB/256GB SSD/14.0" FHD/Intel UHD/Cam & Mic/WLAN + BT/Backlit Kb/3 Cell/W10Pro/1Y Basic Onsite.
Stunningly designed
The Latitude 3410 is smaller and thinner, with a lighter finish and narrow screen bezels to give you more room to work. -
Start quickly, power through
Start up instantly with a fingerprint reader built into the power button. Keep working with outstanding battery life. -
Ports for any purpose
Compatible with more monitors and accessories, with a full range of available ports, including USB Type-C and legacy ports like HDMI and RJ45. -
Fast performance
The 10th Gen Intel Core processor offers businesses the performance, manageability, built-in security features and stability of Intel architecture and aligns to a future-proof roadmap. Plus, you can stream video, download and smoothly run applications with advanced graphics.
- Dell Latitude 3410 - 14" - Core i5 10210U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (10th Gen) 10210U / 1.6 GHz (4.2 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 14" 1920 x 1080 / Full HD @ 60 Hz - 157 ppi
- Graphics
- Intel UHD Graphics
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2/ax, Bluetooth 5.1, Gigabit Ethernet
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- 32.65 cm x 22.638 cm x 1.835 cm
- 1.61 kg
- Pricing Type
- Build To Stock (BTS)
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe
Display
- 14"
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 157
- Image Brightness
- 220 cd/m²
- Colour Gamut
- 45% NTSC
- Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, 35 ms response rate
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Resolution
- 0.92 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- IR camera, RGB camera, 87 degrees
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3204
- High Definition Audio
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111H
- Technology
- 3-cell
- Capacity
- 40 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- HDMI , USB-C 3.2 Gen 1 (supports DisplayPort Alt Mode) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , USB 2.0 , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Office (Trial)
- Security
- ExpressCharge
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.61 kg
- Bundled Services
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 110 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - Extended Service Agreement | In Stock | £40.94 |
Other bundles (11)
Dell Slim DW316 USB External DVD Drive | In Stock | £32.24 |
Dell MS116 Mouse Optical Wired USB Black For Lattitude | In Stock | £10.93 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £15.74 |
Dell KB216 Keyboard USB UK QWERTY Grey Inspiron 24 3459 | In Stock | £14.79 |
Dell Multimedia Keyboard KB216 UK | In Stock | £16.53 |
APC Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt | In Stock | £435.04 |
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £100.76 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £112.43 |
Dell E2020H 20" 1600 x 900 5ms VGA LED monitor | In Stock | £65.19 |
Dell Ultrasharp U2421E 23.8" 1920x1200 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £184.77 |
Dell P2422H 24" 1920 x 1080 5ms HDMI VGA Monitor | In Stock | £120.91 |
