Dell Latitude 3380 Intel Core i5-7200U 8GB 128GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: CVTQWS00 Mfr#: YRN49
  • Core i5
  • IEEE 802.11n
A 13.3-inch laptop built with advanced applications for modern learning and best-in-class durability to withstand every school day. Collaborative construction: A 180-degree hinge allows the system to lay flat, making it easier to share content on the IPS touchscreens with Corning Gorilla Glass and up to 10x higher scratch resistance. Good past the last bell: With 10+ hours of battery life, this trusty PC gets kids through even the longest school days. Designed to be kid-proof: The Latitude 3380 Education Laptop comes with a sealed, spill-resistant keyboard, rubberized edges and Drop Protection, so it can withstand lockers, lunchrooms, backpacks and buses.
  • Collaborative construction
  • Designed to be kid-proof
    The Latitude 3380 education laptop comes with a sealed, spill-resistant keyboard, rubberized edges and Drop Protection, so it can withstand lockers, lunchrooms, backpacks and buses.
  • One machine to charge them all
    The mobile computing cart with a space-saving design makes it easy to charge, manage, and store up to 30 systems at once. An LED light lets teachers easily see that all devices are actively charging.
Dell Latitude 13 3380 - 13.3" - Core i5 7200U - 8 GB RAM - 128 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
128 GB SSD
Optical Drive
No optical drive
Display
13.3" 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
33.29 cm x 23.18 cm x 2.3 cm
1.63 kg
Pricing Type
Build To Plan (BTP)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - response time: next business day
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
8 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
128 GB SSD - (2.5" (7 mm)) SATA 6Gb/s
Display
13.3"
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Resolution
1 Megapixel
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3246
High Definition Audio
Input
Keyboard, touchpad
Communications
Wireless
Wireless Controller
Dell Wireless 1820
Network Interface
Gigabit Ethernet
4-cell
56 Wh
AC Adapter
Input
Output
65 Watt
Connections & Expansion
HDMI , USB 3.0 (PowerShare) , 2 x USB 3.0 , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Security
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
Build To Plan (BTP)
1.63 kg
ENERGY STAR Certified
35 °C
10 - 90%
Get more from your purchase from one of our essential accessories
CVTQ Dicota Privacy filter 2-Way for Laptop 13.3" Wide (16:9), magnetic In Stock £45.88
