Built for durability, reliability and security, the Latitude 14 Rugged Extreme from Dell is designed to deliver dependable performance when it's most needed.
Dell's Latitude 14 Rugged Extreme is designed to meet rigorous military-standard requirements and is constructed from tough, high-quality, shock-absorbent materials. It's compression-sealed, so dust, dirt, sand and liquids are kept out, with gaskets in place to seal all entry points.
This laptop won't flag even when things heat up - its QuadCool thermal management system means it can handle even extreme temperatures. Its alloy magnesium backbone and ultra-polymer materials are robust and durable enough to withstand serious rough and tumble.
It's also equipped with a 1.7GHz Intel Core i7 processor, as well as 16GB of RAM and 512GB SSD storage space - so there's more than enough room for all those essential files. Its nine-cell battery provides up to nine hours of power, giving you no shortage of time to work when you're on the move.
The Dell Latitude 14 Rugged Extreme will be there when you need it most. For an outstandingly reliable and durable laptop, this could be the ideal solution.
Push the limits
For some jobs, you don't know where the edge is until you've already gone over it. That's why Dell pushes to the edge and beyond with a rigorous "test-to-fail" methodology during development and third-party certify the products to meet military standard requirements. -
Built with a backbone
This notebook can take some serious punishment, thanks to its rigid magnesium alloy backbone and shock-absorbent ultra-polymer materials. -
Stays cool under pressure
In heated situations, Rugged Extreme doesn't break a sweat. It's built to last in extreme temperatures with fourth-generation QuadCool thermal management. -
Great visibility outdoors
In all lighting conditions, you can easily stay focused on your screen. The Direct-View outdoor-readable display is designed to reduce reflections, preserve contrast and conserve battery life. -
Backlit keyboard with stealth
With a customizable RGB backlight, you can switch between red, green, blue and white lighting, allowing the keyboard to remain visible but unobtrusive. A stealth key lets you stay undercover, turning off all lights and sounds with a single touch. -
Resistive touch screen
No matter how rough, dirty or cold your job gets, you can work with or without gloves using the resistive touch screen that responds to finger pressure with fluid response. -
Wi-Fi and broadband options
Stay connected out in the field with 802.11ac Wi-Fi and options including 4G/LTE mobile broadband and a dedicated GPS. -
Long battery life
With long battery life from the standard 6-cell battery, you can keep plugging away without having to plug in. -
Universal docking
Easily switch between vehicles and workspaces with universal docking solutions from Dell and Havis that are compatible with all Latitude Rugged products. -
Extensive device support
Connect the devices you use every day, from the latest USB 3.0 peripherals to legacy devices with two serial ports, two Ethernet ports and an optional PCMCIA reader.
- Dell Latitude 14 Rugged Extreme (7404) - 14" - Core i7 4650U - vPro - 16 GB RAM - 512 GB SSD - WWAN
- Product Type
- Notebook - rugged
- Operating System
- Win 7 Pro 64-bit + Windows 8.1 Pro Licence
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (4th Gen) 4650U / 1.7 GHz (3.3 GHz) / 4 MB Cache
- Memory
- 16 GB DDR3L
- Storage
- 512 GB SSD
- Optical Drive
- DVD-Writer
- Display
- 14" WLED touchscreen 1366 x 768 / HD
- Graphics
- NVIDIA GeForce GT 720M
- Keyboard Backlight
- Yes (RGB)
- Integrated Webcam
- Networking
- Bluetooth, Wi-Fi, Gigabit Ethernet
- Wireless Broadband (WWAN)
- WWAN
- Battery
- 9-cell - up to 14 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader, contactless smart card reader
- 35.6 cm x 24.7 cm x 5.2 cm
- 3.54 kg
- Pricing Type
- Catalogue Build to Order (CAT)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Bundled Services
- 3 Years Dell Collect and Return Service
- Product Type
- Notebook - rugged
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro Licence
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 16 GB
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
Storage
- Main Storage
- 512 GB SSD
- Optical Drive
- DVD±RW
Display
- 14"
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Direct View outdoor readable, glove touch mode
Audio & Video
- Graphics Processor
- Video System Features
- NVIDIA Optimus
- Camera
- Camera Features
- 1080p Full HD movie recording, privacy shutter
- Sound
- Speaker, microphone
Input
- Keyboard, touchpad
- Yes (RGB)
- Customizable light system
Communications
- Wireless
- Bluetooth, Wi-Fi
- Network Interface
- Gigabit Ethernet
- Generation
- WWAN
- Technology
- 9-cell Lithium Ion
- Capacity
- 97 Wh
- Run Time
- Up to 14 hours
Connections & Expansion
- Slots
- 1 x ExpressCard/54 (1 free)
- Headphone/microphone combo jack , 2 x USB 3.0 , 2 x USB 2.0 , 2 x serial , 2 x LAN , Dock , VGA , HDMI
- Memory Card Reader
- Yes (SD Card)
- Case Material
- Magnesium alloy, ultra polymer
- Dockable
- Security
- Security lock slot (cable lock sold separately), water-resistant, dust-resistant, noise reduction, anti-vibration, shock-resistant, explosionproof, QuadCool thermal management system, thermal protection, drop-resistant, stealth mode, volume control, resistive touch screen, impact-resistant, Dell ControlVault, Dell Data Protection, cold-resistant, USB PowerShare technology, ExpressCharge
- Included Accessories
- Power adapter
- IEC 60529 IP65, FIPS 140-2, MIL-STD-461F, NIST SP800-147, ANSI/ISA.12.12.01 Class I Division 2 Groups ABCD
- Pricing Type
- 3.54 kg
- ENERGY STAR Certified
- Bundled Services
- -29 °C
- 63 °C
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
