Latitude 5530|i7-1265U|16GB|512GB SSD|15.6" FHD|IR Cam & Mic|Intel Iris Xe|ThBlt|FgrPr|SmtCd|4 Cell|65W Type-C|WLAN|vPro|Backlit Kb|W10Pro+W11Pro Licence|1Y Basic Onsite.
ExpressConnect
Be on 2 networks at once with the world's first simultaneous multi-network connection for faster data and video downloads. -
Wi-Fi 6E
Wi-Fi 6E allows 7 more channels for more bandwidth which provides faster, smoother Wi-Fi, especially in high-density areas. -
Work remote for longer
Long battery life with ExpressCharge provides faster charging speed. -
Intelligent privacy
Onlooker detection notifies you when someone is peering at your screen and will texturize your screen, while Look Away Detect knows when your focus is elsewhere and dims to further protect privacy and save battery life. -
ExpressSign-In
A camera-based proximity sensor wakes your system on approach and locks when you walk away. -
Intelligent audio
Artificial intelligence improves audio and voice quality and adjusts for different environments. Neural Noise Cancellation eliminates unwanted background noise as well as the background noise of the participants on your call. -
ExpressResponse
Based on user behavior, ExpressResponse prioritizes your CPU to improve the performance of the apps your currently using. -
Cool under pressure
Larger dual opposite outlet fan with optimized venting and other thermal improvements keep your system cool even when working with multiple applications. Dell offers the broad range of settings so you can finely tune for the perfect balance of performance, cooling and battery run time. -
Easy on the eyes
Choose the bright 400 nit super low power panel for long battery run time, featuring ComfortView Plus low blue light technology to reduce eye strain for all day working. -
Expansive screen in a small footprint
The small 15" mainstream business laptop also has impressive screen to body ratio.
- Dell Latitude 5530 - 15.6" - Intel Core i7 - 1265U - vPro Enterprise - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro + Windows 11 Pro Licence - Dutch / English / French / German / Italian
- Platform Technology
- Intel vPro Enterprise
- Processor
- Intel Core i7 (12th Gen) - 1265U / 1.8 GHz, up to 4.8 GHz / 12 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 512 GB SSD - NVMe, Class 35
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD @ 60 Hz - 141 ppi
- Graphics
- Intel Iris Xe Graphics
- Input Device
- Pointing stick
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Grey
- 35.78 cm x 23.33 cm x 2.215 cm
- 1.59 kg
- Pricing Type
- Build To Stock (BTS)
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Notebook
- Operating System
- Windows 10 Pro + Windows 11 Pro Licence - Dutch / English / French / German / Italian
Processor / Chipset
- CPU
- Intel Core i7 (12th Gen) 1265U / 1.8 GHz
- Max Turbo Speed
- 4.8 GHz
- Number of Cores
- 10-core
- Cache
- 12 MB
- 12 Threads
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 3200 MHz
- Rated Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 2230 PCIe - NVM Express (NVMe), Class 35
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 141
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Anti-glare, Wide Viewing Angle, ±80° vertical viewing angle, 25 ms response rate, ±85° horizontal viewing angle, 0.179 mm pixel pitch
Audio & Video
- Graphics Processor
- Camera
- Yes - 1920 x 1080 (standard), 640 x 360 (infrared)
- Image Sensor Type
- CMOS
- Video Resolutions
- 1920 x 1080, 640 x 360
- Frame Rate
- 30 frames per second
- Camera Features
- Privacy shutter, IR/RGB camera, Temporal Noise Reduction
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3204
- High Definition Audio
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad, pointing stick
- Numeric Keypad
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6E AX 211 - M.2 2230
- Network Interface
- Gigabit Ethernet
- Dual stream (2x2)
- Technology
- 4-cell Lithium Ion
- Capacity
- 58 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
- Interfaces Details
- HDMI , 2 x USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Office (30 days trial, excludes office licence)
- Grey
- Security
- ExpressCharge, dual channel
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- USB-C power adapter
- FIPS 140-2, FIPS 201
- Pricing Type
- 1.59 kg
Sustainability Information
- TCO Certified
- Bundled Services
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 140 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
Dell Slim DW316 USB External DVD Drive | In Stock | £36.19 |
Dell KB-813 Smart Card Reader | In Stock | £38.69 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £34.21 |
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £50.12 |
Dell SB521A Magnetic Sound bar | In Stock | £35.62 |
Dell MS5120W Mobile Pro Wireless Mouse | In Stock | £25.91 |
Dell Dual Monitor Stand - MDS19 | In Stock | £169.04 |
