The Dell Wired Keyboard provides a convenient keyboard solution for everyday home or office computing uses. The keyboard's full layout with chiclet style keys allows for efficient, comfortable typing - excellent for everyday usage on virtually any task at hand.
                Wired keyboard for everyday home or office useThe Dell Wired Keyboard provides a convenient keyboard solution for everyday home or office computing uses. The keyboard's full layout with chiclet style keys allows for efficient, comfortable typing - excellent for everyday usage on virtually any task at hand.
                Multimedia keys for quick actions and commandsThe convenient multimedia keys let you easily access functions such as play, pause, rewind, and fast-forward plus volume control.
                Comfortable, desk-centric designWith a compact design that still features a full-sized keyboard and number pad, the Dell Wired Keyboard is ideal for home and office environments. With a durable build and quiet keys, it's designed to provide comfort for the everyday demands of desktop usage. The Dell Wired Keyboard also has a palm rest that is available for separate purchase.
- Dell KB216 - keyboard - black Input Device
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Hot Keys Function
- Volume, mute, play/pause, backward, forward
- Keys Style
- Chiclet
- Black
- 44.2 cm x 12.7 cm x 2.44 cm
- 503 g
- 1-year warranty
- Keyboard
- Interface
- USB
- Hot Keys Function
- Keys Style
- Chiclet
- 44.2 cm
- 12.7 cm
- 2.44 cm
- 503 g
- Black
- Cables Included
- 1 x USB cable
- Limited warranty - 1 year
