The KB813 Smartcard keyboard from Dell is designed to offer high security. It is one-stop solution to protect institutional data and intellectual property through a comfortable, stylish keyboard that has an integrated smartcard reader. This Smartcard keyboard provides durable typing solution through spill-resistant, low profile quiet keys with a removable palm rest that helps provide a comfortable typing experience. Its wired connection helps provide secure, fast data and authentication transfers. Moreover, the wired USB connection is easy to connect to virtually any Dell system.
Secure and convenient
Access secured PCs or networks directly from your keyboard. The Dell KB813 Smartcard keyboard has an integrated smart card reader for easy authentication at your fingertips. -
Reliable
Wired USB connectivity helps provide secure, fast data transfers while eliminating the need for batteries. A spill-resistant keyboard safeguards against the inevitable beverage mishap. -
Comfortable and quiet
Work comfortably with low-profile keys, a full-size keyboard and a detachable palm rest. And reduce distractions with a keyboard that's designed for a smooth, quiet typing experience.
- Dell KB813 Smartcard - keyboard - QWERTY - UK/Irish - black Input Device
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK/Irish
- Security Devices
- Smart card reader
- Black
- 1-year warranty
- Keyboard
- Interface
- USB
- QWERTY UK/Irish
- Security Devices
- Smart card reader
- Black
- Limited warranty - 1 year
