15.6-inch laptop perfect for everyday use, in a stylish, thoughtful design. Featuring powerful Intel processors.
Stay connected to what you love
Enjoy quality video chats with a built-in HD webcam that keeps you looking your best. -
Adapt to any situation
Adaptive thermals keep your PC running efficiently, whether at your desk or working from your lap. Your Inspiron 15 intelligently adjusts its power and thermals to keep running smoothly, using advanced algorithms and accelerometers. Plus, minimize your time plugged into an outlet with ExpressCharge, which can recharge your battery up to 80% in dozens of minutes. -
Upgrade for increased style
Upgrade to a sleek aluminum cover and enjoy these extra features. -
Environmentally conscious
Your Inspiron 15 is designed with sustainable materials and ships in packaging made from 100% recycled and renewable materials and is 100% recyclable.
- Dell Inspiron 15 3530 - 15.6" - Intel Core i5 - i5-1334U - 8 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Win 11 Pro - Dutch / English / French / German / Italian
- Processor
- Intel Core i5 (13th Gen) - i5-1334U / 1.3 GHz, up to 4.6 GHz / 12 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 15.6" 1920 x 1080 / Full HD @ 120 Hz - 141 ppi
- Graphics
- Intel Iris Xe Graphics
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac/ax
- Battery
- 3-cell
- Carbon black
- 35.85 cm x 23.556 cm x 1.899 cm
- 1.66 kg
- Pricing Type
- Build To Stock (BTS)
- Manufacturer Selling Program
- Dell Smart Selection
- Environmental Standards
- ENERGY STAR Qualified
- Carbon Footprint
- 288 kg carbon emissions
- Specific Absorption Rate (SAR)
- 1.195 W/kg (body)
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Notebook
- Operating System
- Windows 11 Pro - Dutch / English / French / German / Italian
Processor / Chipset
- CPU
- Intel Core i5 (13th Gen) i5-1334U / 1.3 GHz
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- 10-core
- Cache
- 12 MB
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 1333 MHz
- Rated Speed
- 1333 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
- 15.6" - IPS
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 120 Hz
- Widescreen
- Pixel Density (ppi)
- 141
- Image Brightness
- 250 cd/m²
- Horizontal Viewing Angle
- +80 / -80
- Vertical Viewing Angle
- +80 / -80
- Colour Gamut
- 45% NTSC
- Anti-glare, Wide Viewing Angle, Narrow Border Display, 35 ms response rate, 0.17925 mm pixel pitch
Audio & Video
- Graphics Processor
- Video System Features
- Functions as Intel UHD graphics (for single-channel memory)
- Camera
- Yes - HD
- Resolution
- 0.92 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 78.6 degrees, RGB camera
- Sound
- Stereo speakers, microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Numeric Keypad
- Precision touchpad
Communications
- Wireless
- Wireless Controller
- Realtek RTL8852BE - M.2 2230
- Dual stream (2x2), MU-MIMO
- Technology
- 3-cell lithium polymer
- 190 g
- Capacity
- 41 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- Interfaces Details
- HDMI , USB-C 3.2 Gen 1 , USB 3.2 Gen 1 , USB 2.0 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- McAfee Business Protection (1-year), Activate your Microsoft 365 for a 30 day trial
- Carbon black
- Case Material
- Plastic
- ExpressCharge, ExpressChargeBoost
- Included Accessories
- Power adapter
- 1.195 W/kg (body)
- Pricing Type
- 1.66 kg
Sustainability Information
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 64
- Manufacturing (kg CO2e)
- 237.14
- Logistics (kg CO2e)
- 12.46
- Use (kg CO2e)
- 37.05
- EOL (kg CO2e)
- 1.57
- Total Carbon w/o Use Phase (kg CO2e)
- 250.96
- PAIA Version
- 1.3.2, 2022
- Bundled Services
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 110 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
